    Page 2 of 14 FirstFirst 1 2 3 4 5 6 7 12 ... LastLast
    Results 21 to 40 of 262
    1. #21
      Apr 2016
      Moving along nicely and that hood looks killer!
    2. #22
      Jun 2017
      Utah
      Quote Originally Posted by Jk918 View Post
      Thank you. I have 2 hoods so I felt comfortable experimenting with one and it is turning out better than I expected.
    3. #23
      Jun 2017
      Utah
      I ordered the rear end for my my project finally. I am going with a 4 link and panhard bar. My thought is that I want to be able to set it up for drag racing but return it to parallel for the street. My first live was drag racing so I want to drive to the strip, lay down a low ET, and drive it home. I built a Factory Five Cobra previously and I loved driving that car but every time I stepped on the loud pedal, it smoked the tires like crazy. That was fun but they wouldn’t hook up until I got to 3rd or sometimes 4th gear.
      Anyway, that drove me to the 4 link. I plan to weld the cross member to the rockers (which are in surprisingly good shape) and then put in 2x3 frame rails forward to tie in the front. I’ll put in time outriggers from the rails to the rockers for strength and for the roll cage mounting points.
      The rockers are good but I am considering adding 1/8” plate to the inside to strengthen them a bit.
      The rear will look something like this except I’ll have a panhard bar instead of the diagonal locator in the pictures.
Size:  448.3 KBName:  87AEBFDA-34CB-490E-8CF7-5FDE0555585B.jpg
    4. #24
      How well does that rear suspension articulate?
    5. #25
      Jun 2017
      Utah
      I'm not sure. What is the proper measurement of articulation?
    6. #26
      Jun 2017
      Utah
      I have some time before the rear end shows up so I am trying to hone my painting skills. I had some lead foot gray laying around and I wanted to try my hand at ghost stripes.
    7. #27
      Jun 2017
      Utah
      Custom dash
      I’ve got an idea for a custom dash
Size:  336.2 KBName:  5CCDF5A1-7172-4A68-A0E8-33978F2D06C7.jpg
Size:  357.9 KBName:  6BB50E88-8210-4108-8DDB-E64EF8ECA3EF.jpg
    8. #28
      Nov 2017
      awesome work so far, subbed
    9. #29
      Jun 2017
      Utah
      Quote Originally Posted by JRANGER View Post
      Thank you. I’m having fun in the process and if it turns out nice, that’s a bonus.
    10. #30
      Jun 2017
      Utah
      My brake isn’t big enough so I had to get creative.
Size:  346.6 KBName:  2A6D4015-74B5-47BC-8ED8-66D4E82E262D.jpg
    11. #31
      Jun 2017
      Utah
      I am thinking something like this. A smooth dash with a small sunshade over a 13” LCD digital dash from Autometer. I want to mount an iPad in the middle for entertainment and navigation. I want to recess it just a little to hide the charging cord. I plan to use a Bluetooth amp so I won’t need additional connections.
    12. #32
      Jun 2017
      Utah
      Made a little progress on the dash. I think I’ll paint the dash and cover the shade in leather.
Size:  364.7 KBName:  74C294CD-E79C-404D-AB9F-B4804A2DF6CA.jpg
Size:  300.3 KBName:  F45781B4-4417-4B07-A2DB-9CAE328A8F5E.jpg
    13. #33
      Chesapeake, VA
      That looks promising.
      Cars are meant to be driven.
      John B
    14. #34
      Looking good!
    15. #35
      Jun 2017
      Utah
      Made some progress on the instrument shade. Took a few tries to get it right. 3 dimensions is one too many for me.
Size:  375.4 KBName:  E2B5D89C-E599-41D3-A604-19058D760CC3.jpg
Size:  389.4 KBName:  C5EF8D78-8CD8-4CF9-9B54-87B1F8329EF6.jpg
Size:  341.3 KBName:  5CDFC443-F707-4C30-8708-8FFF0CDD6480.jpg
    16. #36
      Will you be using the big Holley EFI dash?
    17. #37
      Jun 2017
      Utah
      I think I want to use the Autometer Invision unit. I think it fits what I’m looking for a little better.
    18. #38
      Jun 2017
      Utah
      The rear end should be done soon so it’s time to get ready. I have to cut out pretty much all the flooring 26” forward of the rear axle centerline. I plan to weld the crossmember that has the driveline hoop on it to the rockers. The back rails extend back and pick up the rear panel and bumper mounts. I realize this will be much too weak by itself so I am adding a roll cage over the top and building frame rails from the new cross member to the front rails. I’ll connect the front rails to the rockers under the rollbar mounts. That should give me a good solid chassis.
Size:  456.1 KBName:  0CE1DE58-6AC2-431D-8F02-FCF410E3452D.jpg
    19. #39
      Jun 2017
      Utah
      The instrument cluster shade wasn’t quite level so I had to make some adjustments. I think it lines up better now.
    20. #40
      Jun 2017
      Utah
      No going back
      Ok, I am committed now. No going back since I cut out the whole back end. I’ll end up cutting away the rest after install the back half. Name:  7092993A-DBD3-4EC3-8B46-00BB1799A10B.jpg
