    Results 1 to 10 of 10
    Thread: speed tech
      Jul 2014
      speed tech
      I have a 70 nova with speed tech road assault package with weight on front end it makes a snapping noise when turning the wheel
      Sep 2009
      Did you try calling them?
      Central CA USA
      Hard to say but when I've heard that, it was the front sway bar moving side to side.
      May 2010
      kitchener,Ontario,Canada
      Is everything new ... ???
      Ryan Austin
      On Instagram ryanaustinss70
      Jul 2014
      speed tech
      Yes all new car has less than 100 miles on it
      May 2010
      Very odd , have you tried jacking the car up to see if it changes .. and or have someone as another set of eyes or ears to help diagnose the situation
      Ryan Austin
      Oct 2009
      Stick a go pro under there and take it for a ride
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Aug 2022
      steering shaft and or u-joints binding up? or loose?
      Make sure your ball joints are drawn into the spindles.
      '67 Chevelle LS1 T56
      '70 Chevelle 454 T56
      '67 Corvette Conv
      '68 Jaguar XKE
      '68 Jaguar XKE 2+2
      '60 Plymouth Fury Sonoramic Conv
      May 2010
      Quote Originally Posted by Rucumn View Post
      Definitely a decent idea ... id suggest take the car off jack stands so the weight is on it , loosen and re torque all the fastners on everything you replaced, something is Definitely binding being as you told me it only happens when the weight is on the suspension
      Ryan Austin
