Thread: 67 Chevelle SS Restomod
08-08-2022 #1
- Oct 2019
- 273
1967 Chevelle SS
Frame-off restoration
True 138 Vin
CAR HAS TRANSERABLE REGISTRATION (pre-72 NY cars don’t have titles. Any buyer can 100 % title this car with their state. I have prior registration and it says “transferable”). If that scares you, sorry. I’m also
Paint/Body
Brand new paint job painted “Blew Me Away” blue for 2017 Camaro. It’s laser straight, and a 9.9 out of 10 paint job. As close to flawless as you’ll find.
All OG Sheetmetal except rear quarters and trunk pan
All OG floor pans in perfect shape
Brand new chrome, trim, moldings, and emblems.
New windshield and rear glass
Smooth firewall and painted engine bay
Car retains original wire harness
Chassis/Suspension
Frame sandblasted and painted satin black
Right Stuff 4 wheel disc brakes
Power Steering
Tubular upper and lower front control arms
Viking Adjustable coilovers
UMI front and rear sway bars
UMI 4 link rear
12 bolt Auburn Posi, 3.42 Richmond gear
New US Mag Rambler wheels, new tires (225 front, 275 rear)
Drivetrain
ATK High Performance 454 “Stage 3” crate motor (Gen V block) 550HP/570 ftlbs with dyno sheets under warranty
Edelbrock Alum heads, roller cam, roller rockers.
QuickFuel 780 CFM Carb
New fuel tank, electric pump, and lines
Aluminum radiator, dual electric fans
AutoGear M20 4 speed under warranty
Interior
New Door panels front and rear
New carpet
New dash pad, trim, and gauges
New Seat covers
New package tray
Flaws/needs…
Stereo (nothing installed)
Center console (I have the OG with clock, but it needs work)
A/C system if desired
Side glass is driver quality but not perfect
Splines on window cranks are getting stripped, but they still roll up and down fine with pressure
Dome light not coming on
Dash lights not coming on
Vent window trim has light pitting but doesn’t look horrible
Car still retains factory wiring harness. It’s fine but some people like the modern body harnesses. Not needed.
Car will only be held on a non-refundable deposit under predetermined pick-up timeframe. Can assist in shipping within 1000 miles of 29301
$55,000
SPARTANBURG SC
864 597 6885
