      Jul 2013
      N. Scottsdale
      Fuel pressure sensor question
      I making my fuel lines this weekend, and have a question.
      I installed the fuel pressure sensor for the vaporworx system near the fuel tank. I'm using Fast EZ-EFI 2.0, which of course, also requires information from a fuel pressure sensor. My question is whether I can tap into the Vaporworx sensor with the Fast harness, or do I need to use the sensor that came with the Fast kit? If the latter, wondering if the location of the Fast sensor matters (i.e., do I need to locate the Fast sensor close to the Vaporworx sensor, or can I install it towards the front of the car?).
      Mountain Springs, Texas
      Carl is the expert but I would not assume the two senders have the same curve. So use both. As far as where the second one should go I would think closer to the engine would be ok for the Fast but maybe double check with the Fast installation manual. Or maybe Carl will chime in.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Newbury Park, CA
      Want a job Don? ;-)
      Since we don't know if the ramp rate of the sensors is the same it's best to use both.
      The vaporworx sensor should be installed near the outlet of the fuel module to help reduce the chances of picking up pressure pulses from the fuel injectors/mechanical pump. The pulses can cause an unstable idle/light cruise fuel pressure instability. GM typically puts the sensor near the same location as well for the same purpose.
      The ECM sensor, unless otherwise specified, can go near or on the engine fuel rail.
