      Jul 2011
      Nashville/ Tampa
      DIY Full-Length Chevelle console, version 1
      I built this last year or maybe the year before (I forget, I haven't really been home in a year) and am finally about to go back and get some time to work on the car. I'm thinking I might make another one, but with more of an armrest. Anyway, there are a couple similar threads already and I'm just posting this in case anyone else is considering making one.
      The first step was making cardboard templates for the sides, pretty standard stuff. After that I measured the different widths from front to back and cut brace pieces out of wood to match. I don't like the idea of using wood in car projects, but it's all I had at the time. The sides are PVC board from Lowe's, which I left in the FL summer sun for a while and then selectively used a heat gun on to allow me to make the width vary as needed. I then got a sheet of PVC, trimmed it to the same general shape as the top and stuck it on the outsides to create a bit of depth once wrapped.
Size:  232.1 KBName:  20200822_201239_f19b8667916b8ef8cb4d5c9476904e20d5df5dff.jpg
Size:  169.9 KBName:  20200823_115537_1_31c4d3e53bbf9f9b086f8c52caac93c677a836a2.jpg
Size:  70.2 KBName:  20200913_172340_0a1504326fe84001c34db23526af26565294e824.jpg
Size:  139.7 KBName:  20200913_171540_41131b666e1d346dd1cc56be556a28b2443516f0.jpg
Size:  126.0 KBName:  20200823_120648_1_5544c19123640ac37566bb4b98e4584712f32f65.jpg
Size:  90.3 KBName:  20200823_120106_1_94c380acf4fa4adc427fafb7bd760082a04556c2.jpg
Size:  190.2 KBName:  img_20200823_130120_710_1_e097878ac89335e67d89310be31d16cbe6a5cdfc.jpg
Size:  250.2 KBName:  img_20200822_204420_913_1f4a8bca04bb179b1f609257522f0dff5361c2e2.jpg
      Once the sides were settled I made some carbon fiber pieces for the center, cut and drilled as needed, and got the shifter, Restomod Air knobs, head unit and cup holders in place. I still need to mount the power window switches, but there are lights inside the console that shine downward, a single USB port hidden up front and two USB ports on each side of the lower rear. Lots of fun wiring.
Size:  379.0 KBName:  20200907_152630_746e5f6762be8f976e60b15e962b460a3fb349bb.jpg
Size:  201.8 KBName:  20200907_155739_9299fbebf2fe390f4f1fafee09af67fd7793e4e9.jpg
Size:  201.1 KBName:  20200907_161210_b6117f0b3ed0f2c0cad16513afae387e73ecc6d6.jpg
Size:  180.8 KBName:  20200907_123823_cf27f4cea5118c6d0af6079d8f94bed684a60a60.jpg
      Finally, I wrapped it in leather and got everything more or less installed. The aluminum piece in the middle in one of the pics is not actually part of it, it's just kind of in the picture. The green lights look obnoxiously bright in the pics, but it's a longer exposure and reflecting off the Membrane sound deadener. In real life with carpet it's a lot more subdued.
Size:  185.1 KBName:  img_20200913_183421_958_d9a6e6189c209503c1740e862ac14d5e74a9d482.jpg
Size:  164.4 KBName:  20200913_181820_cd31f9ec81e1efd5f976eae3b71e8a8c2cfc3007.jpg
Size:  237.1 KBName:  20200913_182044_d0b39136201bedb4d37604e4ff048bf87ef956d8.jpg
Size:  155.2 KBName:  20200919_180641_2_14f8ce3b6c63557de92f575cbe0d887136a32fe6.jpg
Size:  52.2 KBName:  20200919_180911_2_bb180337bd94269f99a166cd5644e6e013ab408e.jpg
Size:  153.9 KBName:  20201031_163354_1_100a3cae2af849acc7c8e7997fdaa2eda8bfac66.jpg
Size:  119.4 KBName:  20201210_143134_3d7315f5dde3c343b369767df6f1574d0ed22b96.jpg
      That's pretty much it, not really a huge project and something you could do in a day or two if you had all the materials on hand.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
      corona,ca.
      Looks nice.
      Tearing into the chevelle again I see!
      72 chevelle.
      Nov 2014
      Lake Worth, FL
      is the dash from theshopllc ? or is that custom?
      pretty badass looking
      Jul 2011
      Nashville/ Tampa
      Quote Originally Posted by chevelletiger View Post
      Looks nice.
      I did all of this at least a year ago, but in July I'm finally going to get back to working on it. Have a 6.2 in the garage and going with a Terminator Stealth X Max to run it. Going to try to get it running and driving for now, I think the new frame will be delayed until next year since I'm changing jobs and moving this year.
      Quote Originally Posted by Camaro68+69 View Post
      Thanks. Yeah, it's The Shop. It matches the Fesler door panels pretty well I think
      Nov 2014
      Lake Worth, FL
      What rear panels are you using in your convt? I have a 68 Camaro convt that I'm looking for something for..
      Quote Originally Posted by chuckd71 View Post
      Jul 2011
      Nashville/ Tampa
      Panels are Fesler, which I probably wouldn't recommend. I've already cut mine up to make them fit the Morris Classic shoulder belts
    Tags for this Thread
