Results 1 to 1 of 1
New to Pro-Touring
- Sep 2004
- 13
Drive Shaft Installation Issue HELP!
I switched from a saginaw 3 speed to a m21 muncie on my 68 Camaro and kept the original driveshaft. The problem is that the yoke doesn't slide in all the way into the transmission like it did on the 3 speed and doesn't allow enough clearance to bolt the driveshaft to the rear end. Is it possible that I need a shorter yoke? I have tried putting the tranmission in nuetral but that didn't help. The transmissions both have the same length. Any ideas?
James
- 68 Camaro Coupe
