      Jul 2013
      N. Scottsdale
      Oil pan for 2nd gen
      What's the best option for stroked LQ4 (408) in second gen with ridetech True Turn? Mostly street and autox. Would the Holley 302-3, GM fbody, and Mast LS stroker pan all work for this application? Other options? I know subject of oil pans has been covered here and elsewhere, but getting conflicting information.
      I've used the 2002 Fbody pan on a few Fbody LS swaps. One was a LS2 sleeved and stroked to 427 cubes. I didn't put it together but I believe they had to shim the windage tray down to clear the stroker crank. On my non-stroked LS engines I had to trim the windage a bit at the front.
      Jun 2016
      Upstate NY
      I used a 2002 Fbody. Mine is a stroked 427. Holley hangs way too low.
      Jul 2012
      Louisiana
      4th Gen F-body, perfect fit and ground clearance. Only possible drawback is the loss of 1/2 quart oil capacity - 5.5 versus 6 qt.
