    Results 1 to 20 of 25
    Thread: 572 hp LS2
      Chicagoland
      572 hp LS2
      Just finished dyno testing a LS2 for a customer in Hong Kong China.
      It made 572 Hp and 555 lb ft through the stock cast manifolds and cats, with pump gas. To meet emissions we had to run it this way. This was with our tuning to the ecu for spark and fuel.
      Easily will be 600+ with longtubes and 26 mpg.
      Going into a black Ultima GTR
      www.schwartzperformance.com
      :3gears:
      Jeff Schwartz 815-770-0751
      SchwartzPerformance
      Where classic style meets modern performance.
      455 Commanche Circle
      Harvard IL 60033
      SchwartzPerformance.com | Facebook | Twitter
      Sounds awesome. Did you tune with LS1-edit?
      Given that, I have high hopes for my 427 LS2. I should know that number any time now.
      jp
      ​John Parsons
      Mountain View, CA
      Quote Originally Posted by jeff s
      :3gears:
      Wow, that is impressive!
      Can I have one?
      True T.
      My blog
      Chicagoland
      Sure you can have one, just send money. LOL
      SchwartzPerformance
      Harvard IL 60033
      Dunwoody, GA
      what all was done to the engine? those are nice numbers. im assuming that is on an engine dyno not a chassis dyno. if so do you expect the drivetrain to take the standard 15% or less? im always so curious to see what people end up making at the wheels after an engine dyno. have to make sure the standard 15% still holds up.
      Trey
      ~ Jon Hammond
      May 2000
      Quote Originally Posted by WS6
      I'd like to know too. Those are some huge gains over the stock output. Unless there's a power adder involved.
      69LAnd
      was this like a stroker ls2 or a big cam afr or etp heads ls2 ?
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      Mountain View, CA
      By "pump gas" do you mean the stuff bought down at the corner cheveron station?
      I'd like to see the dyno curves. A lot of LSx builds seem to put up impressive peak numbers but are making that power at 6800rpm and are doing nothing below 3000rpm. Personally, I'd rather have a power curve that resembles a Ducati rather than a GSXR.
      True T.
      My blog
      Dunwoody, GA
      hahaha id have to agree. im getting adjusted to my SV650 and man that little thing is torquey. i love it. one day i may have to try a inline four and see how it is.
      Trey
      ~ Jon Hammond
      May 2000
      I'd still like to know how 172 hp was gained.
      Jun 2002
      Long Island, NY
      A set of AFR 205s/225s or comparable heads, a port matched FAST 90/90 setup and a properly sized / matched cam plus bolt-ons will get you there on an LS2. That number is pretty impressive through the stock manifolds and cats, though. I'd like to see the combo specs as well.
      Quote Originally Posted by MarkM66
      Its supercharged.....
      Dunwoody, GA
      sweeeeeet! looks great
      Trey
      ~ Jon Hammond
      69LAnd
      No Wonder Lol ...ok That Explains It All
      Rick M.
      hMMMMMMsss....
      Nov 2002
      Georgetown,TX
      Man,,I need one of those in my El Camino. Now,if I can only find that extra $20K I had lying around,,,,
      Jul 2003
      Anaheim Hills, CA
      I just got all the parts for my LS2 story..
      Comp Cam 230/232 114+2 cam, hardened pushrods, Comp 1.85 roller rockers and a set of the new AFR stage II heads.. oh, and a Meizier elec water pump.
      FAST intake and LS2 TB will top it off along with my stepped longtubes.
      Very curious what it will end up putting out
      Guesses?
      That magnacharger is sweet..
      1968 Track Rat Camaro:
      69LAnd
      HI STEVE are you going with force induction ? hehe which it sounds like you are with your setup
      Rick M.
      hMMMMMMsss....
      Dunwoody, GA
      if your stock cubed and NA you should hit 470s at the wheels at least Steve. i would hope anyway.
      Trey
      ~ Jon Hammond
      69LAnd
      I Would Think Maybe Afrs And That Cam Through A 12 Bolt Hmmm On A Dynojet Yeah Like 470
      Rick M.
      hMMMMMMsss....
      LS 2
