    Results 1 to 13 of 13
      Feb 2022
      Chicago
      Fuel pressure sensor
      Hey y’all!
      Would it be an issue if I want to mount my Fuel pressure sensor upside down?Name:  IMG_5894.JPG
      Sep 2009
      No, it will have no affect on your sensor. I have mine in the same exact position with zero issues. LDM sensors rock!
      Feb 2022
      Chicago
      Awesome! Thanks for the help! I agree about LDM great prices compared to the big name companies!
      Mine is also mounted upside down on my fuel rail for the last 15 years and no issues.
      1971 Camaro
      Feb 2022
      Chicago
      Quote Originally Posted by ULTM8Z View Post
      Awesome, thank you
      I'd add one thing: your sensor will last much longer if you isolate it from engine vibration by mounting it remotely with a bit of hose from the fuel rail. Or, better yet, mount it in the fuel supply line BEFORE it gets to the fuel rails. You'll get a better average value that way as well.
      ​John Parsons
      Mar 2013
      Sunny Calif
      Would signal integrity suffer if not mounted on rai? and worsen the further from the point of outlet?
      Quote Originally Posted by MAGON
      I don't know what you mean by "signal integrity". Do you mean "fidelity"? How close the transmitted value is to the actual value of the fuel pressure? We have a lot of ground to cover to go through what we mean by these terms. Let's assume you mean fidelity.
      Fuel pressure is an interesting case because it's a pressurised liquid subject to heat, with small momentary pressure losses due to the injectors dispensing fuel into the engine. So the fuel pressure does vary slightly all through the fuel supply hose, and if you really want to monitor and analyze fuel pressure, you'd need to add sensors all along the way (before and after each injector, along the hose, etc.). You'd need 10-12 high-quality quick-reacting sensors, plus the ability to record all that at around 200 Hz (there's no way any human being can watch all that data) for post-run analysis.
      OTOH, if this is just for a fuel pressure gauge for the driver to glance at every now and then or to make sure the engine is getting gas as designed (3 bar, 4 bar, etc.), then it's best practice to put the sensor in the fuel line ahead of the fuel rails, or via a flexible line connected to the fuel rails to minimize vibration.
      Hope that makes sense.
      ​John Parsons
      Mar 2013
      Sunny Calif
      thanks for the specifics, much appreciate detail frame rail it it is.
      Feb 2011
      dallas, tx
      I used the same sensor and slowed down the sample rate
      Mar 2013
      Sunny Calif
      Quote Originally Posted by icemanrd19 View Post
      Reason behind slowing sample rate?
      Feb 2011
      dallas, tx
      Easier to see during data logging. Fuel pressure sensor on the fuel rail can change and pick up injector pulsing.
      Mar 2013
      Sunny Calif
      ah, gotcha thx
