    Results 1 to 1 of 1
    Thread: New LS Cam
      Mar 2013
      Sunny Calif
      New LS Cam
      New LS DELTA CAM grind for LS 4.8 through 6.2L (L99 L92 L76) Rectangle Port:
      Engine w/o VVT & AFM
      Three Bolt Cam
      Great daily driver Naturally Aspirated cam with noticeable lope.
      Naturally aspirated it Dynode 450 hp / 410 tq to the wheels in my N/A LS3.
      Wound up dropping a valve and Grenaded engine, sent cam to Delta for a freshen' up grind but instead they sent me a new one same cost, since down have decided to go a different direction with rebuild.
      For Boosted applications:
      Cam is stage 1 Turbo specs compatible for Boosted applications cam will offer better responsiveness in the low-mid RPM range compared to the Stage 2 while having a milder idle sound making up to 1000hp.
      Specs:
      Duration @ .050″ Lift
      Intake 222°Exhaust 232°
      Duration
      Intake 282°
      Exhaust 299°
      Gross Lift
      Intake 0.602″
      Exhaust 0.602″
      114 lobe separation
      RPM Range: 1500 to 6700
      MFG CAM CARD PDF
      cam specs.pdf
      270.00 - Upay ship My loss your gain, trades? whatcha got?
      Attachment 198139
    Tags for this Thread
