      Jan 2013
      Ride Tech Air ride
      ridetech ShockWave v3.0 Air Shocks
      RideTech brings you the latest refinement of the original ShockWave in the form of these ShockWave v3.0 air shocks. They use double-convoluted air spring bellows to achieve the load capacity required for these installations.
      RideTech CoolRide Systems
      These CoolRide systems have the greatest application coverage and versatility of all of RideTech's systems. They will raise and lower the vehicle, improve the handling, and offer a terrific ride. On a front system, the shock is usually relocated to the outboard side of the lower control arm. A weld-on bracket mounts the top of the shock to the frame rail. On a rear system, the air spring and shock absorber will normally go in the stock locations. These CoolRide systems consist of an air spring, a shock absorber, and all of the necessary mounting bracketry and hardware.
      RideTech RidePro E2 air ride Suspension Control AirPod Dual Compressor Systems
      Everything is new system been installed but never used E2 is a old system but can be upgraded this is a great deal. 1700.00 Firm.
Size:  364.6 KBName:  air2.jpg
Size:  357.9 KBName:  air5.jpg
Size:  314.4 KBName:  air10.jpg
Size:  416.0 KBName:  air8.jpg
Size:  211.5 KBName:  air1.jpg
Size:  504.9 KBName:  air4.jpg
      Aug 2012
      Monterey, CA
      Are you in California?
      Jan 2013
      No I'M IN GA
      Sep 2017
      What part of Ga. Are you in? I’m in SC.. Is this a complete kit? Or will I need to get some pieces to complete the kit?
      Dec 2020
      Ride Tech Air ride
      Quote Originally Posted by BadBird68 View Post
      Looks to be complete if they are current shockwaves in front will need to mount to ridetech Strong arm control arms.
      The cool rides i believe are more universal but still designed for certain cars.
      If all new and works this is a good deal.
      Op, what car are these made for?
      what kit? part number?
      what vehicle were they mounted in? stock lower control arms?
