    Thread: T56 install
      Nov 2004
      Pickering,Canada
      T56 install
      hello everyone..........need some help.
      I will be installing a 1996 vortec small block with a 1995 T56 trans in my 69 camaro and my question is.......with the engine in place and bolted up to the engine will the trans hit the floor or does a stock floor pan have enough clearance??????????
      thanks in advance everyone.
      Steve
      La La Land, CA
      If you have stock height subframe body bushings you should be fine. The 1/2" drop bushings cause the tunnel issues.
      Tyler
