    Results 1 to 10 of 10
      Jul 2021
      Houston, TX
      Baer SS4 + 11 Front and Rear
      Hi!
      I'm selling my front Baer Brake system (Front part #: 426-1369B) and rear Baer Brake system (Rear part #: 426-2325B). They were on my 1969 Camaro but I've upgraded to bigger brakes instead. They have never been driven on the streets since my car has been in the shop for ~2 years and are basically brand new. They've only been mounted and used to move my car around the shop, that's it. I'm asking for $1,000 obo + shipping. All hardware along with brake pads are included, except for the hub and brake lines are the only items not included. You can DM or reach me via [email protected] for more details or questions.
      Front: https://www.summitracing.com/parts/bae-4261369b
      Rear: https://www.summitracing.com/parts/bae-4262325b
Size:  240.4 KBName:  23.jpg
Size:  449.3 KBName:  22.jpg
Size:  750.8 KBName:  21.jpg
Size:  530.6 KBName:  20.jpg
Size:  384.3 KBName:  19.jpg
Size:  710.5 KBName:  18.jpg
Size:  497.0 KBName:  17.jpg
Size:  340.6 KBName:  16.jpg
Size:  856.4 KBName:  24.jpg
      Jul 2021
      Houston, TX
Size:  243.7 KBName:  8.jpg
Size:  240.8 KBName:  7.jpg
      Los Angeles
      Are you interested in splitting fronts and rears?
      1987 El Camino SS
      Displacement=357 CID 10-1
      Intake=Lingenfelter SR w/30 lb 52mm TB
      Heads=AFR 195 Street Eliminators
      Cam=Lingenfelter 219/219 .560/.560 112 LC
      Headers=Doug Thorley Tri-y 15/8", 2-1/2 exhaust
      Computer=1227730 NVSRAM S_AUJP_V4 Bin
      Trans=700-R4
      Rear End=GN 8.5 Posi 342
      Brakes= C-5
      Jul 2021
      Houston, TX
      Hi! I'd prefer to sell it as an entire set (Front + Rears) but, if no one is interested in the set, I'll look to split them up.
      Pacific Wonderland
      Are you selling the complete kit as it listed or just the calipers, brackets, and rotors?
      If it breaks I didn't want it in the first place.
      69 GTO
      72 FIREBIRD
      64 BONNEVILLE FUNERAL COACH
      70 JAVELIN
      52 F1 FORD PU
      29 FORD PU
      85 ALFA ROMEO
      ASSORTED DUCATI'S
      91 BLAZER LOWRIDER
      Oct 2019
      Will these only fit a Ford rear?
      Jul 2021
      Houston, TX
      Everything (excluding the front Hub and brake lines)
      - - - Updated - - -
      Quote Originally Posted by vcho455 View Post
      Everything (excluding hub and brake lines)
      Jul 2021
      Houston, TX
      Quote Originally Posted by Kyle Simpson View Post
      The rear kit is designed for a Ford 9 in. With Torino Bearing. If you’re running a different rear end, the only object that will need to be changed is the backing plate BUT I would highly recommend that you call Baer to be on the safe side.
      Quote Originally Posted by samvera31 View Post
      interested in the rear set if you decide to split it.
      Jul 2021
      Houston, TX
      Sold
