      Mar 2021
      Connecticut
      Connect & Cruise LS7 vs. Aftermarket Build
      I am beginning a PT build of a 68 Camaro, and I am planning on using a Whipple Supercharged LS7. The "427" displacement is meaningful for a Camaro lover, and the Supercharger, well, that's just cool. I see several engine builders (Wegner, Mast, etc.) that have what look like excellent offerings in the $30k range. However, GM sells a crate engine LS7 570hp with T56, bell-housing, etc, for $20k. I'm interested in options re: whether it is worthwhile to buy a ready-to-go engine from one of the builders, or buy the connect & cruise for $20k and the supercharger for $8k and adapt the crate engine to accommodate the supercharger (I'm assuming lower compression ratio, different cam, and maybe some head work). I am capable of swapping cams and pistons, and could source head work locally. Interested thoughts on this, and if anyone has practical experience they can share. It would seem less expensive going the crate engine route, but I'm sure the premier engine builders do more than just swap out pistons and cams.
