Results 81 to 100 of 173
05-11-2022 #81
- Jan 2020
- 137
Im not too worried about it. They are more tucked up than it appears. Also I don't plan on running this car in any inclement weather. I've also power washed countless LS engine bays with the coils right on top of the valve covers and never had an issue. I think they are more robust than people give them credit for, but we shall see. If I have to move them somewhere else I will.
05-11-2022 #82
- Jan 2020
- 137
Fuel rail assembled, installed intake manifold, throttle body and valve covers. I'm in love.
05-12-2022 #83
- Jan 2020
- 137
Latest video is up
06-01-2022 #84
- Jan 2020
- 137
Been a few weeks since we've had an update. Been busy with other projects and spring yardwork.
After 5 months my Holley 12.3" dash finally showed up
Which ironically was ordered at the same time as the Terminator X, which has been sitting in the box since January and been moved around the garage 17 times. Finally time to get going wiring this thing.
I think I am going to mount the ECU right on the transmission tunnel underneath my center console. Appears to be plenty of room and the console is easily lifted up and removed with 2 screws if I need to access the ECU. Also hoping to route the harness through the factory gas pedal hole with a grommet, which I still need to purchase.
06-03-2022 #85
- Jan 2020
- 137
Started wiring last night. Got the ECU mounted to the transmission tunnel and the hole in the firewall enlarged enought to pass through the main harness as well as the power harness. Just ordered a large grommet to put in said hole. Ran into a few issues.
1. It appears my DMB terminator X kit does not include the required DBW harness. Guess i'll have to order that.
2. LS3 MAP sensor does not work with the holley pigtail. I beleive I have a MAP in my LS spare parts bin that will work. Should be fine as long as the 1-5V output is the same.
3. Oil pressure sensor is also not compatible. I will be ordering a truck oil pressure sensor that should be compatible.
06-06-2022 #86I bought the appropriate connectors for my engine and re pinned alot cheaper than buying new sensors
1969 frost green camaro
LS3
Speedtech pro touring front subframe
ridetech rear 4-link
moser 12 bolt eaton tru trac 3.73
06-06-2022 #87
