    Results 1 to 10 of 10
    Thread: hard Fuel line
      Apr 2011
      hard Fuel line
      Suggestions on 1/2" hard fuel line.
      Aluminum
      Steel
      Stainless
      Copper-nickel (can only find one distributor - stop shop. Earls only makes up to 3/8 and I wonder why)
      Why one option over another?
      Where would you get it?
      Mountain Springs, Texas
      Heres another source of nicopp. That’s my choice for fuel hardline.
      https://www.summitracing.com/parts/sum-220220-25
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2011
      dallas, tx
      you know that is pretty nice. Making my stainless steel line was such a pain
      Don
      Jan 2020
      Northern VA
      I used aluminum on my car for fuel, I'm using nicopp for brakes, and tranny cooler lines.
      Jan 2014
      Portsmouth NH
      I used NiCopp for my fuel lines and found them to be very easy to work with. I actually used a stock line as a model to bend up the NiCopp, which made for a nice clean fit. The NiCopp is also less reactive with fuel and the road grime that will inevitably contact the outside of the lines. There is a-lot of info on the site about it if you search. I also recommend the Rigid tool flaring tool if you are going to use AN fittings.
      Jan 2022
      I got nicopp for basically everything. Seems pretty easy to make look nice
      Oct 2011
      This was my first time doing brake/fuel lines. Used nicopp for everything. It was super easy to bend and flare. Also, so far no leaks. Really made it a pleasurable experience.
      Ontario, Canada
      I used aluminum for my fuel lines, but at the time I don't think NiCopp had been invented yet LOL.
      I have since used NiCopp on smaller jobs and will use it rather than aluminum next time.
      NiCopp also polishes up nice. Use some fine polishing compound then apply a bit of wax.
      Ken
      My other car is a Vega.
      Aug 2005
      Hamilton, NJ
      How does it age? I've seen some in people's cars turn greenish
      Quote Originally Posted by Kenova View Post
      Ken
      Scott from NJ.
      Vent Windows Forever! ...
      Ontario, Canada
      I haven't had any problems with tarnishing. The wax may have helped with that. I do get a bit of haze on it but a quick buff with a clean cloth brings it back.
      Ken
