    Thread: T56 rattle
      Jan 2016
      Arizona
      T56 rattle
      Anyone else on here have a new tremec that the shifter rattles when you rip through 2nd-4th gear? From 2500rpm up? I finally put weather stripping in my truck and it sounds so much louder.
      When I’m cruising down the freeway in 5-6th and I put a heavy load on it it also does it but I was told that’s normal.
      Jan 2016
      Arizona
      Quote Originally Posted by Cshenker1121 View Post
      Drained the fluid, looked horrible. It was driven STF. Put in some Royal Putple Synchromax and it’s 100 times better. For anyone with this problem.
      Jul 2018
      I've seen where Monolec 1150 is recommended for the T-56. Reports cooler tailshaft temps during testing..
      Jan 2016
      Arizona
      I’m blown away fluid made that much of a difference. Thanks for the info
      Jan 2016
      Arizona
      T56 rattle
      Double posted
      Mar 2020
      Mine had a slight gear chatter if you rest your hand on the shifter.
      Normal driving was not that bad, but it does exhibit enough vibration to make my line lock button rattle.
      I also drained the fluid after about 1500 miles & there was a lot of synchro particles in there.
      It was quieter after a fluid change to the Monolec 1150.
      Jan 2016
      Arizona
      Quote Originally Posted by Lonnies Performance View Post
      Mine was pretty excessive. I had some bad driveline problems from a past shop and long story short I had to replace the tailshaft housing and bushing on a new transmission. When the new shop did that they put the old fluid back in. I’d say it almost rattled worse. New fluid fixed most of it. Still does it but not nearly as much. Very minimal. Might give the monolec 1150 a try down the road.
