    Results 1 to 12 of 12
      corona,ca.
      Spc chevelle lower control arms
      For sale.
      New,only installed for mock up.
      Spc new design 1.5 dom .156 wall lower control arms with progressive bump stops,and spring pocket spc shims,and coil spring cups.
      There over $900.00 on jegs and summit.
      And these come with the bump stops and the height adjustment plates.
      $650.00 plus shipping. PayPal as friends, or venmo NON RETAIL.
      Only reason I'm selling is because I'm going full speedtech,since I have the chicane upper mount.
      Roger,and Adam have been great working with on my application
      Location is corona ca. If buyer wants to pick up.
      72 chevelle.
      corona,ca.
      Taking offers btw
      72 chevelle.
      Sep 2013
      Houston, TX
      Can they be used with factory style springs or must you use coil-overs? Do they have any additional caster built into them? I have SPC upper and want to run more caster but the wheel is not centered in the wheel well, need to move the lower arm forward some to recenter the wheel.
      Rodney Meyers
      72 Olds 442 Rest-mod clone
      corona,ca.
      Quote Originally Posted by cdrod View Post
      Make an offer,I want these gone by the end of this month.
      72 chevelle.
      corona,ca.
      Yes they can be used with factory springs and the plates can be added to raise the height or totally removed to get the drop.
      Additional caster is built into these arms YES.
      And they center the wheel
      Also new.1/2 mounting bolts are included
      72 chevelle.
      corona,ca.
      Bump,price drop $600.00
      72 chevelle.
      What bushings are in these arms? Delrin?
      Los Angeles
      Any idea what the part number of them are?
      1987 El Camino SS
      Displacement=357 CID 10-1
      Intake=Lingenfelter SR w/30 lb 52mm TB
      Heads=AFR 195 Street Eliminators
      Cam=Lingenfelter 219/219 .560/.560 112 LC
      Headers=Doug Thorley Tri-y 15/8", 2-1/2 exhaust
      Computer=1227730 NVSRAM S_AUJP_V4 Bin
      Trans=700-R4
      Rear End=GN 8.5 Posi 342
      Brakes= C-5
      corona,ca.
      Pt# 94344, Delrin bushings.
      72 chevelle.
      corona,ca.
      72 chevelle.
      corona,ca.
      Pending local sale to 74PanteraGTS tonight.
      Also , NO I WONT COVER SHIPPING.
      72 chevelle.
      corona,ca.
      Sold!
      Moderator please remove post,thank you.
      72 chevelle.
