    Results 1 to 10 of 10
      Cincinnati Ohio
      RideTech Track 1 Front Suspension
      ridetech Track 1 front kit for 67-69 F Body or 68-74 Nova.
      Upper control arms, Howe low friction ball joints, ball joint location is moved from the regular arms.
      Lower arm for coil overs or Shockwaves. Howe low friction ball joints, moved shock mount, and drop out mounts.
      Billet spindles, C7 hubs with 1/2-20 long studs, billet steering arms that changes steering Ackerman. Fits any C5/C6 brake kit.
      ridetech Tru Turn, bump steer kit.
      Custom spline sway bar with arms.
      DSE 600 steering box.
      This kit allows you to run a 18x10 with a 275 front tire.
      I ran the ATS upper coil over mount.
      You will need a set of coil overs. I can help with those.
      This front suspension was probably one of the fastest stock sub frames out there with a 275 front tire.
      I will give alignment specs to whoever buys.
      Asking $3500.00 (this kit would be well over $4500 if they still made this stuff)
      Cincinnati Ohio
      Really dont want to ship, but we could talk about it.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Oct 2016
      If you decide to split up please let me know I’d be interested in the spindles. Thanks.
      corona,ca.
      Same here on the spindles, have cash burning �� hole in my pocket!
      Just let me know and I'll pay you in the morning
      72 chevelle.
      Cincinnati Ohio
      Quote Originally Posted by 232_ray View Post
      Quote Originally Posted by chevelletiger View Post
      Wont do that, these parts are all made to work with eachother.
      corona,ca.
      I called ride Tech and believe the spindles are module and the rest of the components are you with their steel drop spindles
      But I understand that you don't want to separate them that's cool
      72 chevelle.
      Cincinnati Ohio
      The balljoints are different on these arms from the non track 1 arms.
      corona,ca.
      No problem changing ball joints for different applications.
      Like I said those parts are module and the person who buys this could keep the spindles and separate the rest if that's all there needing.
      I just thought I'd note this for whoever buys the whole system from you,does have the option to use them in another application.
      From what I was told by the ridetech ,technician,
      The track 1,and Tiger cage were fazed out do to very low sales and since Brett is not involved, and he loved racing,the new corporation,fox holding ls I believe does not want to go down that same road.
      Glws friend
      Merry Christmas, and happy new year!
      72 chevelle.
      Cincinnati Ohio
      Still available.
      Los Angeles
      Are you interested in selling this -DSE 600 steering box separately?
      1987 El Camino SS
      Displacement=357 CID 10-1
      Intake=Lingenfelter SR w/30 lb 52mm TB
      Heads=AFR 195 Street Eliminators
      Cam=Lingenfelter 219/219 .560/.560 112 LC
      Headers=Doug Thorley Tri-y 15/8", 2-1/2 exhaust
      Computer=1227730 NVSRAM S_AUJP_V4 Bin
      Trans=700-R4
      Rear End=GN 8.5 Posi 342
      Brakes= C-5
      Cincinnati Ohio
      Quote Originally Posted by drb930 View Post
      No, wanna sell all together.
