    Results 1 to 11 of 11
      Jul 2012
      eden ga
      Moving battery to trunk
      My question what size wire do I need to move my battery to the trunk of my car?
      I use 02 gauge for both positive and negative. If you have a big draw components you could go up to 00.
      Oct 2011
      Get a 5th gen Camaro positive and negative cable. Used it in my build. Great oem quality and I think it’s a 1/0 cable. Also comes with 2 built in fuses you can use with amps etc.
      https://www.ebay.com/itm/2011-2015-C...-127632-2357-0
      Jul 2012
      eden ga
      That’s a pretty good idea
      Feb 2013
      South Carolina
      Any idea on the overall length of the Camaro cables?
      The other thing I like to do is use isolators that bolt thru the trunk sheet metal. I don't care just just a grommet to protect the cables.
      Oct 2011
      Quote Originally Posted by JustJohn View Post
      I used it in my build. It was plenty long enough for me. I ran it inside the car, then through the firewall (between the inner and outer passenger fender) just like the heat/AC lines, then to the starter. Like I said plenty long enough.
      Jul 2012
      eden ga
      A 2010 camaro positive battery cable is 246inches long.
      Feb 2013
      South Carolina
      Quote Originally Posted by joeko23 View Post
      Sounds like it might get me to the firewall, which is what I need. My car is 18 ft long...
      Jan 2018
      Saint Louis, Missouri
      Quote Originally Posted by 5spd540 View Post
      246 inches ????? That's 20.5 foot.
      Jan 2018
      The gauge of the wire will depend on how much current you are wanting to get through it.
      One might be able to run a front to back 4 gauge cable on a high torque starter turning over a low compression motor but that wire will not be enough if a stock old style starter is used on a high compression motor.
      I've seen cars with 4 gauge and others with 1/0 and it depends on what is needed. You can go to the 1/0 even though you might need a 4 gauge though.
      Also be aware there is copper clad aluminum wire out there (CCA for short) and then there is oxygen free copper wire (OFC).
      A 1/0 OFC wire is close to being like a 2/0 CCA wire. The aluminum wire needs to be larger in gauge than copper for the same ampacity.
      In other words the 1/0 CCA wire is cheaper than 1/0 OFC but the ampacity is lower.
      Oh, and if you can, properly protect the cable with the proper sized fuse and even if it's a sealed AGM battery, still put it in an enclosure vented to the exterior of the vehicle. AGM batteries can vent explosive fumes just like flooded cell batteries.
      Info I've put together through the years:
      https://www.flickr.com/photos/121766...57656656084141
      Jim
