      Jonesboro, Arkansas
      Question about distributor..
      I currently am running a FiTech EFI using a MSD HEI distributor with mechanical advance. FiTech told me that a regular billet distributor with the timing mechanism locked out and the FiTEch EFI taking the control of the timing was a better situation. I can see this. My question is whether to use the MSD Pro Billet distributor at over $300 as opposed to a Summit knockoff and just over $150? I am going to go with the FiTech CDI box. Has anyone used the Summit billet distributor and if so how do you like them?
      Carl Wilson
      Nov 2021
      I'm not using the Summit distributor, but I am using a FiTech EFI unit. It's the MeanStreet 800 though, so it doesn't even have the timing control option available. I went with a distributor from Progression Ignition; it has fully electronic timing control that you set up using an app on your phone. It also has an anti-theft feature built in. I've had mine for 7 months now and am very happy with it. I know this doesn't directly answer your question, but it might be another option you want to check out.
