      Coil over recommendation
      After an eternity I am soon to finally assemble the front end in my 69 Camaro. Looking for recommendations on front coil overs, spring rate etc to suit stock subframe, Hotchkis upper & lower control arms. Will only be used for street duties, no auto cross. I currently have QA1 adjustable shocks and 2 inch Hotchkis lowered springs I’d bought long ago but seems coil overs are the go these days and I like the idea of being able to set the ride height to set the right stance. Engine is an LS3 with A/C, power steer.
      Mountain Springs, Texas
      Coilovers are over rated imho. I’d run the springs and coils.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Michigan
      Don
      I totally agree. Unless your subframe and lower control arms are specifically designed for true coilovers, stick with regular coils and good adjustable shocks.
      If you search on here you'll find plenty of examples of various component failures with the 'retrofit' tapered spring type coilovers designed for stock subframes/control arms. Long story short, they're more trouble than they're worth imho.
      What you have should work just fine. You can cut the coils a little if needed or add spacers in the lower spring pocket to get the ride height perfect if necessary.
      - Ryan
      Beach Park IL
      Welp, you guys got this handled.
      Donny
      Thanks for the advice guys, you’ve just saved me some bucks.
      Southern Indiana
      Personally I'd look at ridetech coilovers and strong arms. If pushing it to the limits the bolt on rear subframe that swaps from leafs to coilovers us a great upgrade to a 4 link system.
      Lee Abel
      AFTERMARKET PERFORMANCE
