Chevelle frame brace install driveshaft issues
Looking for a little advice from anyone that may have installed the latest version of the Chevelle frame brace kit Summit\HPI sells (or really, from anyone that want's to chime in). I got it all welded in, went together without much issue. My car has stock length bilsteins and lowering springs, adjustable length upper and lower controls arms on the rear set to stock lengths (for now, may tweak a bit when I get the weight back on the frame and check driveline angles. I went to install the driveshaft so I can work around it while I rework my exhaust to work and it runs right into the rear cross member. Would need to drop down a couple inches to clear.
Now I'm aware there is little to no weight in the back and it's sitting on the shocks end stops, once I get weight on the car I'm sure the driveshaft will clear. But it seems like now if I jack it up, there will be quite a bit of weight on the driveshaft.. or if I hit a big bump and the car rises up to full extension of the shocks (or not even full, again it'd have to be a couple inches higher to not hit.
I'm not sure if they only designed this kit for cars with rear coilovers or shorter shocks or what. Mostly wanting to see if anyone has any ideas what I could do here or if this may just be a tradeoff I'll have to lift the rear with weight on the suspension. I'm half inclined to think I may be looking at cutting this crossmember out and building something that goes up and over the driveshaft instead of under it. (please excuse my dirty driveshaft, I haven't cleaned it up yet
'69 Chevelle - LQ4/T56
'71 GMC SWB Fleetside - LM7/AR5
