      Aug 2008
      Houston, TX
      FS: 383 SBC Fuel Injection Ready
      Great condition 383ci Small Block Chevy with modern amenities.
      This motor came out of a 1970 Chevy Camaro that I purchase from a retired Airforce veteran in Orange County outside of Los Angeles. He had this motor professionally built and dyno'd at ~450HP. I removed the motor soon after purchasing the car because I had a different setup that I wanted to go with; it has been safely stored since. It is in great condition except some minor missing paint on the block; there is no rust/corrosion, it rotates freely, and runs strong. I am selling the engine because I am moving to a different state. A solid platform for a street machine, weekend racer, or truck.
      Features:
      • Late Model 1986+ SBC 4-Bolt Main w/ 1-piece rear main seal
      • Forged Rotating Assembly including H-Beam Rods
      • Moroso Deep Oil Pan
      • AFR Aluminum Heads
      • Roller Lifters and Rockers
      • High Performance Street Cam
      • Edelbrock Tunnel Ram Port Injection Manifold (port-matched to gasket and heads)
      • Edelbrock Throttle Body
      • Runs on 91 Pump Gas
      • Fuel Injectors/Rails not included.
      I will consider parting it out per the following prices:
      • Short Block: $3000
      • AFR Heads: $800
      • EFI Manifold and Throttle Body: $800
      Or I will sell the full package for $3800 as is.
      Payment: Cash/Paypal/Money-Order/Zelle/Venmo
      Shipping: Local pickup, or buyer pays shipping
      Best regards,
      Moshe
Size:  394.9 KBName:  20130205_102850.jpg
Size:  423.3 KBName:  20130219_214327.jpg
Size:  427.3 KBName:  IMG_0148.jpg
Size:  472.2 KBName:  IMG_0693.jpg
Size:  343.8 KBName:  20130308_010013.jpg
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
      Apr 2016
      How much without fuel injection? Are you moving to idaho?
      Sep 2009
      Looks like it's ready for a EFI connection 24x conversion. GLWS
      Oct 2018
      San Jose, CA
      Which AFR heads ? 195 ? Ported ?
      Internally balanced ?
      What size are the rods ?
      Are pistons forged ?
      Any idea on how long motor has been together and rough mileage ?
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Aug 2008
      Houston, TX
      Yes, I am almost certain they are 195cc Ported.
      I don't know about the balancing and rods, sorry.
      There are a few thousand miles on the motor. When I took the oil pan off, everything was clean, spun well, no questionable debris.
      - - - Updated - - -
      Bump.
      Los Angeles
      If they are AFR Heads, there will be a part number stamped on the front face of each head.
      With the p/n you will be able to determine what they are.
      1987 El Camino SS
      Displacement=357 CID 10-1
      Intake=Lingenfelter SR w/30 lb 52mm TB
      Heads=AFR 195 Street Eliminators
      Cam=Lingenfelter 219/219 .560/.560 112 LC
      Headers=Doug Thorley Tri-y 15/8", 2-1/2 exhaust
      Computer=1227730 NVSRAM S_AUJP_V4 Bin
      Trans=700-R4
      Rear End=GN 8.5 Posi 342
      Brakes= C-5
      Apr 2016
      From what i can see the heads are the older non eliminator AFR heads. Do you know anything about the cam size or what compression this has? Any vids of it running? Why did you pull the engine in the first place?
      Aug 2008
      Houston, TX
      Sold.
