      Oct 2011
      Restomod Air with AAW Harness
      Hey guys, I’m need help wiring up the Restomod Air unit with AAW harness in a 69 Camaro. Can I just use the brown wire referenced on page 10, #24 to power the heater? Also, I need power for the compressor relay. The relay is in the cabin, can I use the same brown wire? Or I need a separate accessory power? If I need a separate accessory power, where do I get this accessory power from?
      Here’s a link to the AAW kit:
      https://smhttp-ssl-87263.nexcesscdn....Design_1_1.pdf
      Here’s the Restomod Air wiring diagram (I circled the two wires that need power):
