Results 1 to 3 of 3
Thread: New here, Lurker for awhile
06-22-2021 #1
- Jun 2021
- 4
Hey guys/gals,
Lurker here for sometime but decided i needed to join. Currently finishing up my 78 TA build. It had a 406 sbc in it with 4spd Muncie that was far from exciting. Here's where i'm at currently..
416 LS3 stroker
Holley EFI
Vintage Air
American Powertrain T-56
BMR upper/lower control arms
Viking coil overs in the front
PSC 12:1 steering box
Camaro pitman arm
BMR front sway bar (stud mounted to frame to prevent bolt pull-through)
Summit rear sway bar
Summit rear lowering leafs (for now)
Billstein rear shocks
CPP big brake kit with C7 hubs
PTFB G-Braces
PTFB-Subframe connectors
PTFB solid mounts
Inside:
SpeedHut Gauges matched to late 70's Trans Am font/style
TMI seats
PTFB roll bar (if i can make it work)
The car will have a shot of the juice just for novelty, probably 150. The build is expected to exceed 600fwhp
The Olds pictured is my wife's car and the first one I painted completely on my own. My father runs a resto shop so i've had my hands in and out of refinishing over the years. Her car has been in the family since new! It's a clone with the following..
425 Super rocket (originally had a 350 at some point over the years it was swapped)
Viking coil overs front/back
12:1 Borg steering box
Had it aligned as close as possible to 4th gen F-body specs as possible with factory arms.
Need to upgrade brakes and control arms.
That's all for now.. Look forward to the forum.
