    Results 21 to 23 of 23
      dayton ohio
      oddball front susp idea
      can anyone tell me where the bumpsteer would end up if i installed fourth gen camaro(ls1) front suspension on a g-body.
      i know that i would have to narrow the inner tie rods to fit the rack and pinion, make supports for the uca/strut. i would also move the lca mounts to the same width as the inner tie rod pivots.
      i would like to get the front suspension set up so that i can run stock 4th gen or c5 wheels with out spacers/adapters on the front and this suspension will clear a 17 x 9.5 wheel easily.
      do you guys see any major down falls to this idea. i am aslo considering the use of the 4th gen abs system (w/ tcs?)
      surgery will soon begin on the three link rear, any suggestions on an IC location?
      thanks
      kevin
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
