      Sep 2017
      RPM Gauge Signal
      I have an LS3 cruise and connect kit from GM. In the wiring harness there's an RPM wire that connects to the RPM gauge. I have speedhut gauges, they supplied a 4.7 ohm resistor that gets wired to the RPM wire from the harness. Once connected as per speedhut instructions, the rpm's don't seem to climb as much as I would think it should. Idles at 500 but just seems sluggish. Has anyone experienced this and what did you do to fix it?
      Thanks in advance
      Perry
      Beach Park IL
      Set tach for 4 cylinder.
      Scratch that it says set tach for 2 pulses per rev when using the ECU signal. Also, the resistor goes between the signal wire and the 12v wire on the tach. It is a pull up resistor as the signal from the ECU is weak.
      https://www.speedhut.com/instruction...ctions2021.pdf
      Donny
