    Results 1 to 9 of 9
    Thread: Oil catch can
      Oct 2009
      Oil catch can
      Hey guys wondering if i can get some input if i installed my catch can correctly. I have the “out” port connected to the port right behind throttle body and the “in” port connected to passenger valve cover.
      Valley port and driver side valve cover are capped
      I have been hearing that the valley port must be on vaccum
      Any suggestions or help is greatly appreciated
      Engine is an LS3 of course lol
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Oct 2009
      Nvm i went with a mighty mouse can and they have detailed instructions. Mine was totally wrong
      LS3
      Mountain Springs, Texas
      Quote Originally Posted by Sinnister69 View Post
      That sounds wrong. Catch can replaces the corrugated hose between the throttle body and valley cover. In connects to the valley cover, out to the throttle body. Fresh air feeds from the intake tube (between the MAF and throttle body) to the valve cover.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2009
      Thanks don im running the holley terminator x system. I dont have a maf sensor in the intake tube. Only a map sensor after the throttle body.
      LS3
      Ok so you can get the fresh air from anywhere you like. But you need fresh filtered air to the valve cover.
      The way you have it plumbed now has no fresh air supply. That’s not good....
      Don
      Oct 2009
      Got the mighty mouse catch can all hooked upName:  64089578326__7EB718E4-4138-4BEC-A2FA-11C0CEDC5F45.JPG
Size:  494.3 KBName:  IMG_5911.JPG
Size:  447.9 KBName:  IMG_5912.JPG
      LS3
      Don
      Dec 2020
      Q; wouldn’t it work putting it inline between the pcv and the intake (I’m working with a TBSS intake and am assuming the LS3 intake has a similar setup)?
      Feb 2007
      Kensington, Md.
      Same question as Tots above, and that's the way I have my tbss plumbed now.
