      Dec 2011
      new york
      Master cylinder bore size
      Good afternoon,
      Looking for opinions on m/c bore size. I have c6 2 piston calipers front, c4 single piston calipers on the rear. I just redid all of the hard lines and new prop valve. The car is a g body which has a stock size of 7/8. Thinking of using a b body master I have that is 1 1/8. Any thoughts? Than you.
      Michigan
      The later C4's, C5's, and C6's came with 1" bore master cylinders. Assuming you're going with vacuum assist, I wouldn't deviate from 1". Make sure you install an adjustable proportioning valve for the rears as well
      - Ryan
      Power brakes or manual?
      Dec 2011
      new york
      Quote Originally Posted by stab6902 View Post
      Thay makes sense, didnt think about that. Thank you
      - - - Updated - - -
      Power
      Quote Originally Posted by 1985olds View Post
      - - - Updated - - -
      Power
      I'd do a right hand drive S10 1" bore MC. Details in my GTO v3 update thread.
