    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    1. #21
      Elk Grove, CA
      I’m looking at an 18”X9.5”, 5X4.75, wheel bolt pattern 5x 120.65, backspace 5.49” and +6mm, would that wheel size work with my set up, would I need a spacer?
    2. #22
      Mountain Springs, Texas
      Quote Originally Posted by elwaupo View Post
      Is this for the rear? It should work with a stock width rear end but it’s tight.
      If it’s for the front I think that’s too wide….
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    3. #23
      Elk Grove, CA
      My current 12 bolt measures 57.75” wide
    4. #24
      So you would need a spacer roughly 1” thick if I did the math right.
      Don
    5. #25
      Elk Grove, CA
      And I just happen to have one 😁
    6. #26
      Elk Grove, CA
      Ok, final question on this fitment, daughter wants to stay with the stock Rally look, will a 15”x10”, 4.5” or 5.5” back space fit?
      Remember my rear end width is 57.75 wide
    7. #27
      Elk Grove, CA
      Anybody?
    8. #28
      A ten inch wide wheel is very tight on a first gen. You will absolutely need to nail the backspacing. There is no room for error. You can try the 4.5 inch backspacing but no guarantees from me. I think you will be 1/4 inch off.
