    Results 1 to 20 of 28
      Elk Grove, CA
      What Back Space?
      Ok, I have a question that I’ve been meaning to ask. I have a 69 Camaro with a 10 bolt rear end which measures 60” width. I also have a 12 bolt rear end out of an earlier Nova that measures 57.57 width that I was planning on using. My question is: what back space would be appropriate for the widest wheel for the rear?
      Pittsboro, NC
      Decide on what size tire you want to run, buy the tires and mock them with rear diff in car. Measure with a tool like wheelrite, etc. This is the only proper way to get exact fit as all these cars can be off 1/4 to 1/2" which can make the difference between clearing and rubbing.
      Mountain Springs, Texas
      Stock Camaro would be 9.5” with a 5.5” backspacing.
      Subtract the width of the new rear end from the original. Divide the difference by 2. Subtract that number from the 5.5” backspacing.
      60-57.75=2.25
      2.25/2=1.125
      5.5-1.125=4.375 backspacing
      Don’t forget to adjust for any offset introduced by non stock brakes.
      If you want to give yourself a little wiggle room add .25” to the backspacing so you can adjust with a small spacer.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Lawrenceburg, TN
      60-57.75=2.25
      2.25/2=1.125
      Don
      ^^^^ yep
      Elk Grove, CA
      60-57.75=2.25
      2.25/2=1.125
      Don
      I agree, that is great information! Thank you
      Elk Grove, CA
      I think they would have to be special ordered, most wheels are either 4” or 4.5” backspace
      Oct 2011
      Try searching for a euro bolt pattern like 5x120. That’s same as 5x4.5” bolt pattern. Much more options out there. You can use an offset calculator to see what the conversion is from mm to inches. For example if you plug in 12” width rim and want to have 5.5” offset that equals 25mm on the calculator. Plenty of 5x120 wheels that are 12” wide with 25mm offset.
      https://tiresize.com/wheel-offset-calculator/
      Quote Originally Posted by joeko23 View Post
      You meant 4.75" bolt spacing, not 4.5" which is the Camaro pattern.
      Oct 2011
      Quote Originally Posted by 68Formula View Post
      Yup! Sorry
      Quote Originally Posted by elwaupo View Post
      Go with 4.5” backspacing and add a small 1/8” or so spacer if needed.
      Don
      Normal, IL
      Since nobody else mentioned it, if you're planning on putting disc brakes you need to factor in rotor thickness and wheel spoke to caliper clearance.
      Quote Originally Posted by badbu68 View Post
      Post #3:
      Don
      Oct 2015
      4.75" is 120.65mm so while 120mm may bolt on it is definitely not ideal. Chances are it will vibrate.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Aug 2005
      Hamilton, NJ
      +1 they are not the same
      Quote Originally Posted by Alwhite00 View Post
      Scott from NJ.
      Vent Windows Forever! ...
      To add, it creates a lot of stress on the studs which could result in failure.
      OP,
      The wheels would need to fit hub centric to the car they are going, and then PCD variation bolts (aka wobble nuts) could be used to properly mate the lugs to the wheels. Here's a good explanation: https://www.team-bhp.com/forum/tyre-...s-reality.html
      I'm sure there are people that have gotten away with bolting them straight on (after all, there is some tolerance variation to everything), but that doesn't make it a good idea.
      Oct 2011
      Check out this thread. I personally put 5x120 on my Camaro. The wheels I purchased come setup for conical lug nuts. I also bought a hubcentric adapter and everything bolts up and is free of vibrations. People have done this and are currently doing it. Maybe I’m just making myself feel better about the situation. Time will tell.
      https://www.thirdgen.org/forums/whee...-vs-5x120.html
      Aug 2005
      Hamilton, NJ
      A while back one of the engineers from AME put up some diagrams showing the stress on studs for both proper 120.65 fitment and 120. The 120s had so much more stress on the studs. Iirc his comments were along the lines of lots of folks do it, but I wouldn't. I decided he's smarter than I am, I'll listen to him. To each their own. I like headrests, 3 points, US made suspension parts and no one in the back seat with rollbars too lol.
      Scott from NJ.
      I remember that thread with the FEA analysis. The trouble was that he did not post a scale with his simulation results which made it pretty much impossible to draw any real conclusions from. He subsequently deleted it.
      Don
      Elk Grove, CA
      �� That’s a lot of information
      - - - Updated - - -
      Don
      Thats looking like the best bet, keep it simple
      Elk Grove, CA
      Post #3:
      Don
      I’m running the stock disc brakes at least for now. Hopefully that won’t be a problem.
