02-01-2021 #1
- Jul 2019
- Ventura ca
- 5
Speedtech upper control arm clearance
Hello I ran into a problem today and was wondering if anyone can help give me some insight. I have a 70 nova that I ls swapped and am finishing a speedtech front and rear suspension upgrade on using the stock front subframe. I am having clearance issues with the upper control arm on the passenger side and the header. As you can see the header is very close nearly touching the bushing area. I'm sure other members have done the same or similar upgrades to what I have done and I was wondering what headers have you used? I am currently using Doug's 83337 ls swap headers for the nova, dirty dingo swap plates on the second most forward mounting holes, the engine is nearly touching the firewall, and a g force trans crossmember. I would prefer to continue to use a long tube/full-length header. I realize I may just have to bite the bullet and get the speedtech header but if I can avoid spending 1500 on it that would be ideal.
02-01-2021 #2
- Jun 2019
- 5
I don't know how complete the rest of your drivetrain is but could you raise the transmission tailshaft some? You can probably just shim the trans mount up with ~1/4" metal pieces. Adjust pinion angle to match. It won't provide a lot but it might be enough. Cost effective backup plan it to clearance your headers some
02-01-2021 #3
- Jul 2019
- Ventura ca
- 5
I've got a t56 I suppose I forgot to mention that part in the original post. Unfortunately im about maxed out there to not much room to go up atleast not with out chopping up the floor
02-02-2021 #4
