    Results 1 to 12 of 12
      Feb 2018
      London, Ontario Canada
      Radiator Core Support Schematic
      Doing a swap to LS3 and already purchased a rad with fan. Would like to make an aluminum support as the original isn't wide enough for the new rad. My original has been smashed at the bottom so I don't want to use it to get critical measurements. Does anyone happen to have the dimensions for this?
      Jan 2020
      Northern VA
      What car?
      Feb 2018
      Ya that would be helpful...... 69 Camaro, thanks
      Oct 2019
      I saw something this morning that was interesting for ideas. Google Rhoades core support. Tubular that looked pretty easy to make
      NJ
      That Rhodes Custom Auto core support is a nice piece.
      Here are the measurements of the one from AutoRad, which currently closed shop and supposedly Cold Case is taking over their production...
      Feb 2018
      Cheers, you guys are the best. I'll let you know when I'm finished the piece
      Feb 2018
      I am about 3/4 complete with this, I'm also machining clutch and brake pedals and shifter. Hopefully this weekend I'll have the core support complete. Thanks again John.
      NJ
      Great, can't wait to see the finished product!
      Feb 2018
      My core support is nearing completion. I have to install the frame mount and fender mount brackets yet. Let me start by saying I am not a master fabricator. Sometimes you have to look at a project and decide if you are better off spending the money on just buying it rather than making it.Name:  TCKV3046.jpg
Size:  291.6 KB I started by having one of my designers transfer my scribblings to a solidworks sketch. He changed my numbers because he thought they would be better. Thus the welds in the middle where I had to narrow it and shorten it. Never start fabbing something without checking your measurements!
Size:  481.4 KBHere is the start before I found it was too big.Name:  IMG_4638.jpg
Size:  396.0 KBName:  IMG_4639.jpg
Size:  376.1 KBHere are the plates for mounting. One inside flush with the tubes for the fender mount. The other covers the tubes in front for the subframe mounts.
Size:  342.9 KBName:  IMG_4677.jpg
      Here is nearing completion. Thanks again John for providing data for me to start with.
      Feb 2018
Size:  350.1 KBName:  IMG_4694.jpg
      Made brackets for frame mount and fender mount. Frame mounts seem a little big, likely machine them down a bit.
      NJ
      Looking good! Nice work!
      Oct 2015
      Western Mass
      Looking forward to seeing this installed! Love these DIY projects!-Mike
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
