    Page 3 of 13 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
    Results 41 to 60 of 245
    1. #41
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by David LaBuda;[URL="tel:1350292"
      1350292[/URL]]I'm happy with the weld-in ididit collapsible mount I used on my Chevelle. You'd want to double check that 2" is the right diameter but I think that's right.
      https://www.summitracing.com/parts/idt-2401020010
      i not for sure yet ,
      but I might use the original!
      i like what you did looks very clean.
      im hoping to make do with materials I have on hand.
      Thank you sir
      David Sloan
    2. #42
      Aug 2002
      Waleska Ga.
      Small update over the last few days, in between rain and cold windy days.
      Started blasting the passenger side door jam and quarter panel, this will take some time to finish but I have the time as opposed to paying $1000+ to have the car blasted.Name:  23321D5C-55BA-47A9-A72E-CE125A9CB1A4.jpg
Size:  369.2 KBName:  37CA010C-B93D-4CF4-AF85-0270856EE386.jpg
Size:  457.9 KBName:  E6960136-EAD4-4531-84C1-4D4FDACFF3DC.jpg
Size:  341.8 KBName:  DCAD986B-189E-4B5D-8682-137CE67A8515.jpg
      David Sloan
    3. #43
      Aug 2002
      Waleska Ga.
      Some pictures of the steering columns side by side Name:  0AD3932B-48D1-419A-BF38-5BCF43AE0A49.jpg
Size:  327.4 KBName:  B69C208B-C6D1-4099-9550-246B0C478FFB.jpg
Size:  398.6 KBName:  7A748E1C-D5A2-412C-B86B-5A1B156B10B8.jpg
      David Sloan
    4. #44
      Jun 2008
      Acworth, GA
      Amazing work, as always, David!
      It looks like you are about to the point where I need to come over so we can set the seat up for me! You know I say that in jest since my money is no good. :-)
    5. #45
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by gardnerme;[URL="tel:1350542"
      1350542[/URL]]Amazing work, as always, David!
      lol! You are always welcome at my house!
      seat mounts are pretty much done, I’m sure you would fit just fine!
      problem is I’m building this one for me.😊
      I’m sure we could find one for you!
      David Sloan
    6. #46
      Feb 2013
      Good work!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    7. #47
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by Josh@ridetech View Post
      Good work!
      Thank you sir!
      David Sloan
    8. #48
      Aug 2002
      Waleska Ga.
      Worked on the firewall today! Little more clean up then on to blasting some more of the body!
      Also made improvements to my windshield wiper install!Name:  8001B09D-F23E-4456-AB18-CBE9D03A4753.jpg
Size:  539.9 KBName:  F3BE0C70-708B-4DFD-8AB4-30D0F3C2366F.jpg
Size:  415.7 KBName:  752D7DB6-21AF-43F5-854A-7BA390A1F105.jpg
Size:  377.0 KBName:  FCD4A719-074B-411B-BD5B-DD1503EC00B7.jpg
Size:  464.5 KBName:  ED463AF4-7332-4824-84C7-3BD3EB020376.jpg
Size:  480.8 KBName:  95F9BD19-F2F1-467A-8C03-1A5CE84F611E.jpg
      David Sloan
    9. #49
      Aug 2002
      Waleska Ga.
      Working on the firewall this morning , got a little more done and things mocked back up.
      Its really nice weather today so I'm about to take the mocked up parts off so I can get it outside to blast some more
Size:  348.5 KBName:  IMG_5177.jpg
Size:  410.8 KBName:  IMG_5178.jpg
Size:  506.6 KBName:  IMG_5179.jpg
Size:  507.0 KBName:  IMG_5180.jpg
      David Sloan
    10. #50
      May 2010
      kitchener,Ontario,Canada
      I like the new column mount , Im curious what is the wiper motor from and will you still have a park feature for the wipers
      Ryan Austin
      On Instagram ryanaustinss70
    11. #51
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by raustinss;[URL="tel:1351021"
      1351021[/URL]]I like the new column mount , Im curious what is the wiper motor from and will you still have a park feature for the wipers
      The wiper motor and the steering column is from a 4th gen Camaro. And yes the park mechanism is still on the wiper motor from the 4th gen.
      David Sloan
    12. #52
      May 2010
      Quote Originally Posted by David Sloan View Post
      Thanks, its a much nicer looking wiper motor vs the originals , also gives you intermittent. Anymore details to share on doing the swap ?
      Ryan Austin
    13. #53
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by raustinss;[URL="tel:1351043"
      1351043[/URL]]Thanks, its a much nicer looking wiper motor vs the originals , also gives you intermittent. Anymore details to share on doing the swap ?
      yes sir!
      the steering column was pretty simple, I took the steering wheel and air bag with the wiring off of the column. Then I test fitted the steering wheel I plan to run , all looked good so I moved to the mounting on the column. The two bolt on the Camaro column was much wider than the Elcamino so I took a couple measurements to verify that the mount off of the Elcamino column would fit if I cut part of the Camaro mount off.
      it looked like a good fit so I cut the mount down enough to tack weld the Elcamino mounting plate to the Camaro column. Once that was done I test fitted it to the body.
      So now I liked it so far and got to a point where I could get to working on the firewall again. Tried to keep it simple and cut a little more of the original firewall away. I started fitting a piece of 20ga sheet metal to cover most of the firewall.
      the wiper motor had already been mocked up a couple different ways until I found a way that I liked and it would function correctly (checking it without power by hand) to make sure it would turn without hitting anything and be timed correctly.
      the next test will come after I get the wiring connectors and power it up!
      That will be a while!
      Hope this helps!
      David Sloan
    14. #54
      Aug 2006
      fort myers florida
      nice project David, like to see some A body love.
    15. #55
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by wayne70 View Post
      Thank you Wayne!
      Always loved the A body's before the Camaros i owned a lot of Chevelle and Elcamino's
      David Sloan
    16. #56
      Aug 2002
      Waleska Ga.
      Update , it’s been cold but I’m loving the shop as it stays at a good working temperature of 66 degrees ��
      So back to the Elcamino. I got some more blasting done and put the frame back under the body,(squared and bolted in for the last time) it goes on the rotisserie next.Name:  F6E130A6-6146-4CF5-BB48-54E0B5BD62D3.jpg
Size:  512.9 KBName:  1109CFDB-2EE4-40A5-8164-AB4069CC358E.jpg
Size:  459.0 KBName:  393E83C7-B26E-4579-B180-C344892AB8F1.jpg
Size:  542.1 KBName:  74D52BBC-5C4B-4BB0-8C89-049F727C5B8A.jpg
      David Sloan
    17. #57
      David,
      You got a very interesting arrangement with the crossmember on the front frame horns. Presumably it doesn't interfere with anything?
    18. #58
      Aug 2002
      Waleska Ga.
      David,
      Hi Andrew
      No sir it does not interfere with anything.
      I have had it all mocked of a couple times now, It is a little more trouble to get the 2nd gen trans am sway bar off but worth the effort I think. As I'm sure you know the front frames tend to sag on these a body's . This really seams to have help with that as i have done a visual test with a jack in the normal location with motor an trans. installed. (Before and after the added bar) I could not see any movement after the install that i had seen before it.
      This should also help with any frame rail flex at the steering box and idler arm location.
      Thanks for looking!
      David Sloan
    19. #59
      Aug 2002
      Waleska Ga.
Size:  580.0 KBName:  19A07E64-7566-4F5C-9F05-72FACC94061F.jpg
Size:  394.3 KBName:  E03A4E8C-9020-4735-83DA-697489ADB054.jpg
      David,
      David Sloan
    20. #60
      Aug 2002
      Waleska Ga.
      Well the shop is a wreak but the Elcamino is on the rotisserie!Name:  423968DF-3A00-445F-93F7-C45336EF96F0.jpg
Size:  517.3 KBName:  962CE106-48C8-4154-9E3F-D7C2662E1706.jpg
      David Sloan
