      Mar 2010
      67 Camaro LS2 Silicone Radiator Hose?
      Can anyone recommend a silicone radiator hose combo that will work with this setup? I'm running an LS Entropy radiator with both Inlet & outlet on the passenger side. Thanks in advance.
      Jacksonville, FL
      Silicone or rubber (if it matters)? Which side is your water pump hose fitting on? Drivers or Pass side?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jun 2010
      Deployed
      May I ask why you want a ~$100 each silicone hoses?
      1970 Camaro/DSE build
      Just FYI. On the C10 forums a guy that had a similar issues as above. He used an ICT thermostat adapter to use a Billet Specialties small block thermostat housing. The ICT adapter uses a LS thermostat. Looked pretty cool.
