      Katy,TX
      Varishock coilover, spring hits shock body
      Is it normal for the spring hit the shock body when a coilover is compressed?
      Central CA USA
      No.
      Are the springs 2.5" ID?
      Do the lower spring seats have an inner ridge to keep the coils centered?
      Katy,TX
      Varishocks
      Yes, they are 2.5" springs and the lower spring seat has a lip that holds it centered. 200 lb spring on a shock with right at 5 inches of stroke. When the shock is compressed several inches the spring lightly contacts the side of the shock body.
      Central CA USA
      I"d try flipping the coil over.
      If there is much side force on the shock body, the shaft and seal can wear out faster.
      It could be a bad spring, I've seen them bend to one side and rub but the better springs won't do that.
      Katy,TX
      Qaulity spring
      OK, I'll try flipping it over. Thanks.
