      Nov 2020
      The Netherlands
      Country Flag: Netherlands
      C1 corvette lsa 6l90 build
      Oke here we go, needing some experience.
      Building a C1 Corvette with a LSA / 6L90 combo and ready to order a Art morrison chassis.
      The big Q is, order it with a power or a manual rack and pinion steering ??
      Since the engine has no powersteering pump and the donor car (2014 Camaro ZL1) had electric steering and a booster brake set up.
      (we going to adapt the ZL1 brakes also)
      In my opinion the ideal way is, going with a power rack and pinion steering and a hydraboost brake unit.
      Sooo... is there a way to adapt the front drive system so we have, all the LSA stuff working AND a powersteering pump added ??
      Any help welcome
      Mountain Springs, Texas
      I think what you want is an CTS-V accessory drive. That is what I have on my LSA.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2020
      The Netherlands
      Thank you Don
      What year accessory drive parts you are using ?
      I looked up some pictures , that should work.
      I found the bracket and pump in my stack off left over parts, only thing missing now is the right pulley, seems a close fit.
      Wander
      Quote Originally Posted by Specialpartz View Post
      Thank you Don
      Wander
      I think any drive from 2009 through 2015 CTS-V will work. They all had LSA engines.
      Don
