    Results 1 to 1 of 1
      Jan 2021
      Florida
      1970 Barracuda Hellcat Resto-Mod
      Car is located in Fort Lauderdale, Florida.
      Price for the car is $95,000.
      Eric Small (646)388-0899
      Well over $100k invested. All the hard work has been done.
      Needs paint and assembly.
      I have most of the parts.
      Originally a 318 car and I have the original matching numbers engine, transmission and rear end that will go with the car.
      US Car tool Level 3 chassis stiffening kit and mini tub.
      Custom Roll Cage tied into all the suspension mounts.
      New sheet metal lower half rear quarters,
      trunk floor, complete firewall, rear deck filler panel, trunk gutter.
      Tunnel modified for T56 Magnum.
      RMS Front suspension, 6.2 mounts (3/4" forward), power steering, Rack and Pinion, racing sway bar, ridetech coil-overs, frame satin black.
      Wilwood 14" SL6 front brakes, drilled/slotted, flex line set.
      Willwood 14" SL4R Rear brakes, drilled/slotted, w/ parking brake.
      9" rear end housing and axle package, new round-back housing low profile, Narrowed 6" with drain plug and vent, SS brake line with Tee, all brackets welded, powder coated satin black. Alloy 35 spline axles - 2.5" offset, big ford bearings (78 ford truck), studs installed, access hole in flange for retainer nuts.
      9" Center section, nodular Iron case, alum pinion support, 1350 yolk, Tru-Trac 35-spline diff, 3.25 gears.
      Wilwood 15/16" bore master cylinder kit
      Wilwood adjustable proportioning valve
      TTI 2" headers for late Hami with RMS suspension (driver side starter) polished ceramic with thermal barrier.
      TTI 3" x-pipe system, dynomax mufflers, tailpipes to fit with RMS rear suspension.
      Boze Alloy Clutch Wheels, 18" x 12" rear, 18" x 9" front
      Nitto NT-01 Tires 335/30/18 Rear, 275/35/18 Front
      Silver Sport T56 Magnum complete transmission kit with Quicktime bellhousing, twin disc clutch, aluminum drive shaft.
      Hellcat engine with 3000 miles along with upgraded injectors, pulleys, pumps, pin kit, etc.
      Ricks Tanks stainless steel custom fuel tank with Hellcat pump inserts
      Wizard cooling Complete radiator and brushless fan setup.
      Vintage A/C
      Dakota Digital Gauge package
      Racing Seats, Car also comes with original bucket seats in excellent condition.
      Bumpers have been powder coated satin black
      Misc brackets powder coated
      I have more that goes with the car that I am probably forgetting about.
      Much love and attention to detail has been put into this car so far and will be the perfect platform for somebody to finish off with their own personal touches.
      See dropbox link with all the inspiration and pictures of the work done so far.
      https://www.dropbox.com/sh/j1vdz7sqj...lS3T6HxHa?dl=0
