      Feb 2018
      London, Ontario Canada
      Eaton 10 Bolt Posi Disassembly
      Rear end is out of my 69 Camaro. I have removed the 5/16 bolt that holds the pin from falling. It isn't broken yet I can't get the pin out. If I pound on the pin with an aluminum punc I can move the pin 1/2" either direction then it stops dead. I've tried spreading the 4 springs in case they are touching the pin but no luck. Any ideas on how to get the pin out? Every other rear it's hard to keep the pin in place, slides right out. I'm at a loss here, anyone have ideas? Need to pull it apart to get drum plates off and install disc brackets.
      Thanks all.
