      Sep 2018
      Closeout / Bulkhead
      Anyone know who makes a closeout for between the trunk and passenger compartment for a first gen Camaro?
      I saw a three piece setup awhile back but Google isn't helping locate this item.
      Point me in the right direction.
      THANKS
      I made mine out aluminum sheet. 1/8" thick was a bit over kill thickness wise. Made a pattern for each piece out of card board and then cut them out with a sabre saw. Riveted them in. Plates on the inside of the bulk head. Rivets from the inside of the trunk for a clean look.
      Local welding shop has sheet aluminum. Or you could use steel also.
