    Page 6 of 40 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 ... LastLast
    Results 101 to 120 of 786
    1. #101
      Quote Originally Posted by BonzoHansen View Post
      Loving this thread.
      Andrew, what's the part number on that MC?
      It is a Raybestos part number: MC390572
      Hey Andrew I have a question about the pedal ratio. So in my 69 Camaro, I also have 2 holes (top) for Manuel and bottom for power brakes. I modified my master booster mount to 3 degrees which is what DSE reduced angle mount is. The question is, shouldn’t we use the upper (Manuel) hole because of the reduced angle? If we use the lower hole, the angle will be different and might hurt the master, no? That’s at least my thinking. I could be wrong.
      I haven't mocked anything up yet, but I think the angle on the booster is not as critical as the angle on the MC itself. Maybe someone else has some insight into this...
    2. #102
      Jan 2014
      Austin, TX
      as long as the pushrod angle into the booster isn't excessive, resulting in binding or rubbing, you should be fine. it is important to make sure the booster and master cylinder are in alignment. definitely use the appropriate pedal hole for your application or you will have issues.
      1972 C20 Suburban
      1964 Corvette Coupe
    3. #103
      Oct 2011
      So in this case what would be the appropriate pedal hole? The lower hole (power) or upper hole (Manuel)?
    4. #104
      Jan 2014
      Austin, TX
      Whichever hole is appropriate for your brake system. If you are running power brakes, and have the rod attached to the manual hole, you're going to find that you have little to no stopping power.
      If you're unfamiliar with the difference, I strongly recommend doing a quick google search on "brake pedal ratio". Using the different holes to fix master cylinder alignment issues is going to set you up for a poorly functioning brake system.
      I'm unfamiliar with the specifics of the DSE Camaro master cylinder, but given the number of pro touring Cameras on the forum, I imagine someone has found the right combo.
      1972 C20 Suburban
      1964 Corvette Coupe
    5. #105
      Oct 2011
      I guess your right, you would put it in the power or lower hole to maintain the correct ratio. Since it’s going through a booster and not directly into a master the angle doesn’t matter at that point.
    6. #106
      Jan 2014
      Austin, TX
      correct...as long as the angle into the booster isn't ridiculous...if I had to guess, the pushrod angle from my pedal into the booster on my C20 is somewhere in the neighborhood of 3-5 degrees....maybe. That being said, given the master cylinder is mounted directly to the booster, that pushrod is perfectly aligned.
      1972 C20 Suburban
      1964 Corvette Coupe
    7. #107
      Some of the upgrade parts are rather mundane. I have always had manual brakes on the GTO, but as the goal for the update is to make the car a little more refined and improver driver comfort, I will be adding power, vacuum assisted brakes.
      This is the new MC that I purchased from Tobin at Kore3. Tobin has always been selfless in his sharing of information and back in 2008 I ordered the C6 Z06 front brakes from him. This is the 1" bore RHD S10 master cylinder that I plan to mate with a Tuff Stuff 9" dual diaphragm booster and a DSE reduced angle firewall mount.
      Might need to add this to my car Andrew!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    8. #108
      Feb 2019
      Kankakee IL
      I spoke to tech at Wilwood before modifying the mounting brackets on my wagon and was assured that the master cylinder being level is fine.
      Tracey
    9. #109
      Quote Originally Posted by Tsaints1115 View Post
      That's very good to hear!
    10. #110
      Aug 2005
      Hamilton, NJ
      Thank you
      Why that one over say a C5 MC? The SAE line fittings? Both at 1" bore with left side outlets.
      Scott from NJ.
      Vent Windows Forever! ...
    11. #111
      Thank you
      Right...The C5 MC has metric bubble flare ports and the S10 has the SAE inverted flare ports.
    12. #112
      Aug 2005
      Hamilton, NJ
      Thanks again
      Scott from NJ.
    13. #113
      The latest round of parts isn't exactly sexy, but I feel like they will offer some incremental improvements.
      This is a dual 9" diaphragm booster from Tuff Stuff. It will work great with the S10 MC. I also plan to get the DSE low angle bracket.
      Since my engine started life as a L92, the valley cover didn't have a vent. The truck engine PCV systems get clean air from the driver's side valve covers and dirty air comes out the passenger valve cover. The LS3 valley cover has a great baffle system in the valley cover and and outlet that can be looped right back into the intake.
      This makes for a very clean installation.
    14. #114
      TuoCo, CA
      When you call DSE they sell a seal and plate that will work better than what came with the tuff stuff booster. Not available standalone on their website.
      I’m also sure you’ll check this but I had to machine my booster pushrod in that same booster as it would not have let my mc release. Looking forward to following your progress!
      Steve
      Check it Out Here
    15. #115
      If anyone is interested, I put my current engine up for sale:
      https://www.pro-touring.com/threads/...nd-ECU-harness
    16. #116
      Not much interest in my engine, so it will just probably be a cam swap and call it a day...
      Another thing that I plan to do is implement pwm cooling fan control. This is sure easy to do with any Holley EFI system (except Sniper). I can keep my current fans and add a C6 fan controller (probably need two) or I may upgrade the fans to the latest brushless design (I have some Chevy Volt fans that might fit well).
      The fan control strategy will also integrate AC and vehicle speed. I have this working on my Cougar already, although without AC integration. Here is a video to see how it works in action:
    17. #117
      Feb 2019
      Which cam will you go with?
      1968 Cougar - 408, FiTech, AOD, TCI, Currie, RideTech, Wilwood
      1968 Skylark - 462, TKO 600, RideTech, CPP
      1985 Mustang - 04 Cobra/Terminator Swapped
      1988 Mustang - Vortech V3, Boss 327, Magnum, MaximumMotorsports, StopTech
    18. #118
      That's a nice setup Andrew, you can't ask for any better control than that.
    19. #119
      Aug 2002
      Waleska Ga.
      Yes sir that is sweet!
      David Sloan
    20. #120
      Quote Originally Posted by STREETFIGHTER50 View Post
      Good question. I like the cam that's in the Cougar. It's the Summit Ghost cam. If I go "off the shelf" it'll be that one.
      If I go custom, it'll be ground by Cam Motion.
