    Page 2 of 43 FirstFirst 1 2 3 4 5 6 7 12 ... LastLast
    Results 21 to 40 of 852
    1. #21
      Subscribed... Can't wait to view your wiring expertise...
      No pressure...lol
    2. #22
      May 2010
      British Columbia
      That’s an impressive pile of parts there Andrew , did Holley cut you a deal since you are one of their top tuners ?
    3. #23
      Jan 2014
      Austin, TX
      Looking forward to the updates, especially the wiring as I have plans for a similar "motorsport style" arrangement when the time comes to do the wiring in the Vette.
      1972 C20 Suburban
      1964 Corvette Coupe
    4. #24
      Quote Originally Posted by FLYNAVY53 View Post
      The harness won't be a full on "motorsports" deal, but more like a "sportsman" style installation. I just want to clean up some of the move visible parts of the harness, so everything looks as tidy as possible.
      Continuing our Christmas theme...On the fourth day of Christmas....LOL
      Holley really knocked it out of the park with these Hooker Blackheart, stainless swap headers. These are the full length headers for the GM A-bodies with 1 7/8" primaries. The welds are beautiful, with the tubes fully welded to the inside of the head flange and ground smooth. The tubes are also partially welded on the outside of the head flange for added strength. I'll probably hit these with some acetone and a Scotchbrite pad for a cleaner, slightly brushed look.
      My buddy Todd, was the man behind engineering the swap components for Holley and he did an outstanding job. All of the swap components are engineered to work together in order to place the engine as low as possible in the front crossmember. This optimizes the driveline angles, which are a big concern when doing a LS swap on the A-bodies, especially with lowered ride height.
    5. #25
      Newbury Park, CA
      That's a nice looking set of Headers. On early F-body chassis there usually is insufficient room to have the O2 sensor outboard. Does the A-body have sufficient space for an outboard mount?
    6. #26
      I am pretty sure there is room. I don't exactly recall how things are under the car at the moment. The TerminatorX only has one O2 sensor and that will go in the passenger side. I will also install my trusty FJO NTK in the driver's side header and have that as an input to the ECU.
    7. #27
      Feb 2007
      Tinley Park, IL
      Is this the car you run the CV driveshaft on? If so, is it still performing to expectations? I'm strongly considering one due to my poor driveline angles and pulsing vibration at highway speeds.
      Nick ~
      1969 Cutlass
    8. #28
      Quote Originally Posted by Mr Nick View Post
      It is indeed. Getting the CV shaft made the car very smooth at all speeds. I am using one on the Cougar as well and it is the only style of driveshaft that I will ever use. Give The Driveshaft Shop a call. They will fix you up.
    9. #29
      Feb 2019
      Kankakee IL
      We're all adults here. You don't have to spell the bad words.
      Tracey
    10. #30
      Quote Originally Posted by Tsaints1115 View Post
      Which bad words? LoL
    11. #31
      Mesa, Az
      Get the CV drive shaft!! You'll be amazed at the difference.
      -Paul
      1969 Camaro "Reckn8"- LS7/C4 Front and Rear
      1965 Oldsmobile F/85 LS6 W/Maggie, 6-speed,Ride Tech, Baer brakes
      1978 Blazer 2 wheel drive with LS power
      1965 VW bug. All original
      1968 GMC short box
      1964 Buick Riviera
    12. #32
      Austin, Tx
      Will you be able to keep everything in a close-enough final position to not have to replace the DS? Or is there more adjustability in the length with the CV? I wouldn't think so, but am curious if the new swap components will move things forward or aft?
      Bryan (a.k.a. Carbuff)
      70 Camaro RS Hunk'o'Metal - Previous Project
      71 Firebird Project T.O.W. - New Project
    13. #33
      Quote Originally Posted by carbuff View Post
      I will most likely need a different driveshaft because I am also going to switch the transmission.
    14. #34
      Feb 2019
      Those headers are sweet! Full SS too
      1968 Cougar - 408, FiTech, AOD, TCI, Currie, RideTech, Wilwood
      1968 Skylark - 462, TKO 600, RideTech, CPP
      1988 Mustang - Vortech V3, Boss 327, Magnum, MaximumMotorsports, StopTech
    15. #35
      On the fifth day of Christmas, I got jewelry...
      The Holley fuel rails are super slick. They use a bright dip anodizing process that really makes the rails and the fittings shine.
      The AN-6 to rail adapters use an o-ring to seal against the rails. The kit also includes adapter brackets that can be used both on the Gen 3 and Gen 4 intake manifolds and can accommodate various injector heights.
    16. #36
      Feb 2019
      Brushed stainless looks awesome especially when they start changing color from the heat
    17. #37
      Feb 2019
      Are you sticking with the same trans? What y’all think of that new Tremec TKX?
    18. #38
      Quote Originally Posted by STREETFIGHTER50 View Post
      I like it a lot!
    19. #39
      Feb 2006
      BC Canada
      Subscribing
    20. #40
      Waterloo, Ia
      This thread might bring me back home here. After the photobucket ransom debacle I kind of quit forums. I've got a 70 Chevelle project on deck in a few years and this will all be super useful info. I sure do miss the forum platform.
      -Nick
      -1967 GTO I drive and race
      -Build threads:
