    Results 1 to 10 of 10
      Hurst T56 Magnum Shifter Exploded View of Design
      Hello PT people,
      I decided to document taking apart my Hurst Magnum shifter to see if there is anything I can do to help seal it a bit better in case in the future it starts to leak. There are several threads on here previously documenting leaks. The most recent one from BobinFL - https://www.pro-touring.com/threads/...ng-T56-Shifter
      This is just to show what I found and if you guys can chime in on what you think can be done or not done.
      I should note that this is something I have not personally experienced yet. I cannot say it will leak, but for the sake of just tinkering I decided to investigate this a bit more. I have used the std t56 Hurst billet shifter and I do like the feel, so I really hope to use this shifter in the Magnum.
      BlackJack Hurst T56 Magnum Shifter:
      In the pictures you will see how loose the seal is to the shifter ball shaft. I think this over time will cause fluid to push through, but it should also let the fluid drain back. The pivot ball from my view would create the positive seal to keep any fluid from coming out. At least this is what I think will happen. Now there are reports of leaking shifters, so my guess is the wear in the pivot ball and the underneath seal start to deteriorate causing it to leak.
      Another contributing factor is on a 1st gen Camaro they have you place the shifter in the forward position which will expose teh seal to more fluid.
      The seal used is very similar to that of the stock t56 and billet plus shifter. Close enough that you can fit and I would say use it as a replacement if needed.
      Hurst OEM and Billet Plus Shifter:
      In comparison Here is the Billet Plus Shifter and a Stock t56 Shifter. I have rebuilt them several of them through the years. These are some pics I took a few years ago.
      In the OEM and Billet plus application the pivot ball shaft is larger and the seal provides a better fit.
      Looks like possibly adding material via heat shrink or other to help seal was my first thought, but as pointed out in another thread, it may not survive the heat cycles and trans fluid very long.
      Any thoughts?
