      May 2006
      Barrington, IL 60010
      Detroit Speed Quadralink Rear Swaybars (2)
      UPDATE:
      Both swaybars have been SOLD !!!
      Thanks, Pro-Touring.com
      FOR SALE: Two used (2) Detroit Speed Quadralink rear sway bars for 1967-69 Camaro/Firebird and 1968-74 Nova. One is 1-⅛" diameter, the other is 1-¼". To be fair, 1st swaybar sold gets bushings PLUS brackets. 2nd bar sold gets bushings only; only have one set of brackets. If in need of kit hardware (that I have re-used), quite sure a call to Kyle at DSE can make that happen for you.
      1-⅛" Swaybar: With bushings and brackets (no other hardware). Rated 311 lbs./in.-front hole; 364 lbs./in.-rear hole.
      1-¼" Swaybar: With bushings and brackets (no other hardware). Rated 496 lbs./in.-front hole; 580 lbs./in.-rear hole.
      $125 each plus shipping.
      Rich
      'Wicked Witch'...1969 Camaro, Mast Motorsports LS-3, Magnum T-56, DSE suspension & BFG Rival-S on Forgeline wheels.
      A herd of stock #'s-matching '69 Camaros.
      Apr 2016
      Pm sent
      May 2006
      1-⅛" swaybar has been SOLD !!!
      1-¼" swaybar is still available.
      Rich
      May 2006
      Thanks, Lateral-G
      Rich
