      need help with unisteer manual R&P
      i am currently installing the unisteer manual r&p kit with their shaft kit to a stock column. the car is primarily used as street/strip car so i was after the weight savings more than the handling.
      the shaft kit i received was pretty poorly put together, the threads on the bracket had been powder coated and i had to re-tap them for the bolts and support bearing to thread on...also the bracket was not labeled (frameside) the instructions were also very incomplete. and trying to get ahold of their techline is next to impossible ( i know its christmas, but ive been calling them since last week no one picks up).
      right now im stuck trying to fit on the lower shaft (which has to be cut to fit) ive cut i want to say about an 1.5inch to 1.75 already. im wondering why are the angles are so harsh? ive fit it on to test it and the u joints bind on themselves when i turn the steering wheel because of the angles being so extreme. im wondering if maybe i have the bracket on wrong...i have the support bearing flush with the framside of the bracket; so it just to the end of the threads on the bracket and not sticking out. and also the bracket is mounted with the support bearing higher than the bolts making an "A" shape and not a "V". do i have it upside down? does anyone have any pictures of the manual kit mounted on their car? this is a 68 camaro SBC, hooker supercomps.
      TIA!
      Ttt
      Oct 2005
      unisteer manual r&P first gen camaro
      I just installed the manual R&P in a 67 big block camaro with 2" hooker super comps. Install went smooth, except some carefull adjustments were required to make the steering shaft kit fit. The kit I used includes 3 u-joints. The frame bracket used to mount the rod-eye for shaft support was mounted pointing down, ie shaped like a V, which is per the supplied instructions. When installed as instructed, the kit does create very sharp u-joint angles. There was very slight interference between the u-joint halves at certain points of rotation. However the interferance was eliminated by carefully rounding the sharp outside corners at the points of interference using a die grinder with a fine stone. It is important to only round off the offending corner, and not to reduce the cross section of this highly critical component. A failure here could kill someone. Also, it is important to use a fine stone to prevent deep grinding marks. you do not want to create any stress risers. After rounding off the corners, be sure to blend the ground area to the non-ground area gently. Again, avoiding sharp corners that can create stress risers. After grinding, the reworked area should be polished to ensure fatigue strength. Keep in mind, I only removed maybe .020 of material, replacing a sharp external corner with a radius, and never reduced the cross section of the part. After this mod, the steering shaft assembly works well. This was a 5 hr install, including reworking the u-joints.
      pittsboro, nc
      still sounds excess for what is sold as a "bolt on kit". unisteer needs to be more honest about the installation requirements before some less-carefull person goes stictly by the instructions & then takes a test drive. a bind-up could kill someone.
      Oct 2005
      Fruits of Labor
      Have about 300 miles on the car since the Unisteer manual Rack installation. Unisteer's honesty about installation effort aside, the system works fantastic. On-center slop is non-existant. Feedback and feel are excellent. It's as if you can feel every pebble in the road. Steering effort when stopped is definately high comparted to the one finger power assist originally on this car, but not excessive. It was certainly worth the effort to install correctly. I will be checking the shaft system regularly for a while though!
