      Sep 2017
      Chevelle Rear Seat Frames
      I'm trying to find new rear seat frames for my 68 Chevelle 2-door coupe. This is impossible. Lots of 70-72 options so the big question is, are the rear seat frames the same for model years 68-72 and what's the differences? The floor pans, wheel houses and rear fire wall are all the same so it would seem that seat frames should also be the same. Heeeeeelp
      thanks in advance,
      Perry
      May 2010
      kitchener,Ontario,Canada
      Stock replacement or ???? What do you have in mind
      Ryan Austin
      On Instagram ryanaustinss70
      Oct 2016
      I just went through this 68-72 GM A-body rear seat frames are the same. Problem is there are 2 different widths. My Tempest has just cardboard style door panels with bottom seat frame length around 54”.
      Other A-body seat frames I looked at were close to 4” narrower. The cars that had narrower frames had plastic style panels on either side.
      Seems the lower base cars had the longer length seat frames.Hope this helps.
      Oct 2016
      Just realized gave wrong measurement. My bottom seat frame measured 58.
      May 2010
      Im still wondering what you want to do ? What's wrong with your stock one ??
      Ryan Austin
      Sep 2017
      Unfortunately I don't have the original frames but I do have frames from a 69 Buick GS. The lower frame measures 56.5" and the backrest measures 55.75". Only thing that seems strange is how high above the floor pan the frame sits. Is this normal?
      Thanks in advance,
      Perry
