    Thread: 2.5 vs 3
      Dec 2011
      new york
      2.5 vs 3
      Good afternoon everyone,
      I broke a hangar on my exhaust and unfortunately, I think that might be the last straw for this system.
      Car is a g body with an NA LS3/tremec magnum. On the dyno the car made 500.1/475 at 5900/4xxx to the tire through a 2.5" exhaust.
      Now that its time to redo the exhaust, I'm looking for opinions on 2.5" vs 3" pipe. Thank you
      Mar 2020
      At your power level a 3" should be of benefit, but I'm not sure what system you presently run or the noise level you are accustomed to.
      3" pipes tend to be louder, so there is a tradeoff.
      Dec 2011
      new york
      Quote Originally Posted by Lonnies Performance View Post
      Thank you. Current system is 2.5" with an x pipe and borla pro xs mufflers, exiting behind the rear tires
      Run 3" through the mufflers and then reduce to the 2.5" tailpipes you already have. Will make the same power with less increase in noise (assuming you also run an X pipe and 3" Pro XS mufflers).
