      Sep 2014
      Backspacing for a square setup
      Alright guys, I'm doing things a bit backwards and letting my wheels define rear axle width.
      My have a '71 Fbody subframe from Speedtech, and I'm using their rear TA setup with DSE mini tubs.
      So my question to you all is if I wanted to run a square 315/30/18 setup what are the backspacing numbers I should be looking at?
      Beach Park IL
      It's not backwards, it is the right way to do it. I did the same with my Camaro, actually had to widen the stock axle housing in my case.
      Figure out what fits in the front. Order 4 of them. Put them under the car where they need to go and then build your axle.
      Did you mean 315/30-18?
      Donny
      Sep 2014
      sounds like what I'm trying to do
      and yes, 315/30R18...
      Beach Park IL
      So your question is what backspacing should I run with a SpeedTech eXtreme front subframe?
      I would think speedtech could provide you with an actual backspace number and wheel width for their front suspension.
      Donny
      When you say "square", do you mean same size wheels on all 4 corners? I keep seeing this term, but not sure what it means, lol. Thanks in advance.
      Lawrenceburg, TN
      Quote Originally Posted by redbull396 View Post
      same wheel and tire size front to rear, and front to rear track width as close equal as possible
