      Mar 2015
      GM Wiper Motor Home Position
      Does any one know if you can reset the home position on a wiper motor. My motor goes past its home position when you turn on the wipers. Best way to describe the problem is wipers move 90deg home position is 15deg for some reason. If i put the wipers on at the home position then turn them on the hit the cowl.
      Nov 2018
      Unless the motor or arms are worn, the problem isn't the motor. The wiper blades need to be moved. There are directions showing how to remove them online. You want them to lay horizontal to the ground on the glass.
      Dec 2018
      Quote Originally Posted by Vimes View Post
      This. And after you remove the arms, switch the key on and turn wipers on, then turn wipers off with the key still on. Watch for the wiper shafts coming through the cowl to stop that shows the wiper motor "parked", then you can switch key off and reinstall the arms.
      All that is assuming you don't have hidden wipers, where the wipers drop back behind the hood when off. Those instructions are for wipers that stay visible on the glass from outside the car when off. I didn't see what you were working on.
      Mountain Springs, Texas
      The arm on the wiper motor might be 180 degrees off. Remove it and flip it over. It should point to the center of the car when parked if I remember right.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
